Home > Maintenance & Mods (L322) > TD6 Bleed Points
TD6 Bleed Points
Does anyone have these noted down anywhere as the only one i know of is ontop of the header tank and i need to replace that stuffing coolant hose again Sad FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #368817 25th Jan 2016 12:37pm
Just remembered good old Joe90 did a thermostat and pump change a while back and listed a rave doc!!
So big thanks to Joe90 i have now found there are two bleed taps i have.
One on something called the coolant rail and another on the EGR. For the EGR im guessing its just a take the cover off jobby but the coolant rail i have no idea about! Any help anyone? FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #368819 25th Jan 2016 12:46pm
Number 7 is the coolant rail. It seems to have a bleed screw fitted to it just in front of oil filter.
The other bleed screw appears to be on the top of item 18.
Post #368821 25th Jan 2016 12:55pm
Mercy buckets NDF!!!
Item 15 is the offending pipe I'll be replacing tomorrow night but those pesky hidden bleed points should now be visible with some cover removal so big thank you!!
The one on item 7 may require some contortion.... FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #368825 25th Jan 2016 1:18pm
