Home > Technical (L322) > TD6 2004: Very moist breather hose
le25dse
Norway 2014 Range Rover Vogue TDV6 Loire Blue
Hi there,
I took a couple of pictures of something that looks to be a breather hose next to the oil filter. I just wonder if this is normal, or a symptom that I should investigate?
2014 tdv6 (ex. 2004 td6, 1997 2.5 dse)
Post #368518 23rd Jan 2016 9:11am
Are you sure you don't have an oil leak in the vicinity of the oil filter.
Lots of oil around there.
I'd be inclined to clean off all the oil and take it from there. Thumbs Up
Post #368566 23rd Jan 2016 4:23pm
As above, clean it up then see if it comes back.
Could just be spillage from swapping the oil filter over in past services Thumbs Up There is nothing that can't be fixed with a hammer😜😜
Post #368567 23rd Jan 2016 4:32pm
le25dse
Thank you for your advice. I will clean up and make an update after some time again. ----------
Post #368846 25th Jan 2016 4:02pm
