Home > Technical (L322) > Reverse lens
chefkenmore
Scotland 2014 Range Rover Vogue SE SDV8 Loire Blue
Reverse lens
Hi guys,
Do the two pieces of lens stick together? Or should they clip together??
Took mine off to replace a bulb and can't get it back together again!!! 2014 vogue se
Post #368548 23rd Jan 2016 2:24pm
the reverse lens is stuck together to the grey bit...if you've replaced the bulb then you should be able to get the whole unit back on with no problems.. ... - .- -.
Post #368551 23rd Jan 2016 2:46pm
chefkenmore
Mine has come apart Stan !
Glue it back together then ? 2014 vogue se
Post #368552 23rd Jan 2016 2:50pm
thats the way Chef, here's a thread re replacing the bulb with leds but it will give you an idea of whats what...
http://www.fullfatrr.com/forum/post308616.html#308616 ... - .- -.
Post #368553 23rd Jan 2016 2:54pm
chefkenmore
Thanks Stan ,
Glued back together now! Just giving it some time to set! 2014 vogue se
Post #368554 23rd Jan 2016 3:08pm
nice one Thumbs Up ... - .- -.
Post #368555 23rd Jan 2016 3:18pm
