![]() | Home > General (L405) > Is the 3ltr really noisy or is it me?? |
Autobiography Member Since: 10 May 2011 Location: UK Posts: 925 ![]() ![]() |
I have a SDV6 L494 an an SDV8 L405. I personally think the SDV6 is quieter and more refined! |
caymanblack Member Since: 08 Dec 2015 Location: DEVON Posts: 1162 ![]() ![]() ![]() |
I have never heard any one complain that the 3.0ltr is noisy, its a great smooth engine. Some thing is not right. |
martincfreeman Member Since: 15 Mar 2011 Location: Flatlands of Lincolnshire (but the Kerbs are pretty high!) Posts: 30 ![]() ![]() ![]() |
That's what i thought, thanks for the confirmation. It is annoying as both the dealer and Land Rover customer services are saying "that's what they do" I am going to test drive another 3ltr next week but I can't believe that it should be droning like this. Heartbreaking! |
Heartbreaking that the dealer had it for a week and then tell you nothing is wrong. Try another dealer hopefully they will be a little better, hopefully. |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7997 ![]() ![]() ![]() |
Test drive another ASAP - if it's better, then insist on driving yours and another back to back with the dealership tech person with you so that you can point out the difference - even if you have to agree to pay their labour time if you're wrong.
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16334 ![]() ![]() ![]() |
I drive both often and the 3.0 is noticeably quieter than the 4.4 in almost all circumstances sir... Definitely something wrong with yours |
Basilfawlty Member Since: 18 Oct 2015 Location: Cheshire Posts: 655 ![]() ![]() ![]() |
Hi, I had a 3.0tdv6 l405 and changed a month or so ago. Considered the Sdv8 because it's a strong unit and there is something about having the bigger engine (SC excluded) but went and bought another v6, primarily because it's noticeably quieter and more refined in real world use. I used to have a Touareg V8 Diesel and that sounded very similar to a petrol V8 but definitely much nicer sound than the LR counter-part! |
Thanks for that, it enforces my thoughts that something isn't quite right. Will keep you posted. |
MattyB Member Since: 01 Sep 2015 Location: London Posts: 16 ![]() ![]() ![]() |
What sort of "droning noise" is it? My MY16 TDV6 definitely makes a droning noise from the left side (left as I am sitting in the driving seat). It's there when I start the car and at idle/low revs, disappears pretty much when I am driving along normally and then reappears once I'm idling again.
Hi mattyb, on the l322 it would have been the fuel burning heater which was standard on the tdv8. I had that n mine. This noise is more like a drivetrain issue. I can believe that the land rover techs in the customer services are agreeing that the 3ltr should make a different noise at a steady speed. It is really noticeable between 30 and 40mph a if all tdv6 variants did this there would be a lot more mention of it... Unless I am hearing things... Going to try and test another 3ltr over the weekend or Monday. I simply can't believe that it is anything other than a fault on this particular car. |
Lets us know how you get on Martin. |
Ok, phae 1 completed....
22" wheels i dont believe it. |
Mine is quieter and better riding on the 21s compared to an identical car I had on 22s. |
