![]() | Home > Technical (L322) > Inconsistent vibration at around 70 |
RR2008HSE Member Since: 06 Jan 2013 Location: British Columbia Posts: 2932 ![]() ![]() ![]() |
The cowl at the bottom of the windscreen can vibrate and cause a buzzing noise. Would that be it? |
cirks Member Since: 15 Sep 2014 Location: Dark Side Of The Moon Posts: 55 ![]() ![]() |
Hi,
diesel Dave Member Since: 14 Aug 2015 Location: Stockport Posts: 469 ![]() ![]() ![]() |
Check you don't have a brake calliper sticking on. Rear ones are quite common for it. Next time it does it pull Over and see if one wheel is getting warm. Did it on mine a couple of months ago, was o/s rear. |
Thanks - will definitely check that. As I mentioned, I did dab the brakes a few times when it happened and it didn't seem to make any difference. However, while we were away over New Year when the car performed perfectly for 6 days and decent mileages, when we stopped once the near-side rear brake did smell hot - I had forgotten about that! |
tb10 Member Since: 17 Feb 2015 Location: Bromsgrove Posts: 339 ![]() ![]() ![]() |
I'd be taking the two front tyres off and examining them for damage as it sounds like the tracking has worn the inside edges. A visual inspection with the tyres on the car may not be adequate unless you have relatively new tyres of course.
again, thanks for the input. I'll take a closer look at the new tyres. However, why would this be inconsistent even at the same speeds if tyre related? |
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1396 ![]() ![]() ![]() |
I've had this with sticking brakes, no difficulty tracing due to clouds of smoke, yours is maybe just starting and the brake pistons retract enough most of the time. In my case it was passenger side front. Only Range Rovers since 1988 |
the rear off-side disk certainly seems to be getting warmer than others and looks like the pad is not sitting flat (ie there's a clear narrow band around the center of the disc vs the inner and outer parts).
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1434 ![]() ![]() |
I'd pull the pads out the caliper and make sure everything is free to move as it should. However, if it's been rubbing as bad as you say, then expect the pads to be burned out. V8 or else ... |
Thanks. Will see what G and G say in the morning. I'm happy to do most things to brakes myself but the RR is a new beast to me (let alone sorting out jacking it due to the side steps having to be removed - hence getting G and G to look first!)
Thanks all for your inputs
