Home > Maintenance & Mods (L322) > L322 / strange electronic issue
Riedland
France 2006 Range Rover Supercharged 4.2 SC V8 Java Black
Hi all, it's not too late to wish you to enjoy your FFRR in 2016.
Mine has started a strange phenomenon this winter : it's the fifth time in 2 months that at morning departure from cold the gearbox is late to shift so the engine revs higher than normal. When this occurs I can notice the water temperature gauge needle is still full on the left side of the dial after a 3 mn ride. To fix this I simply stop the car and like a computer novice, switch the engine off and restart immediately, the needle then rise to where it should be and the gearbox has a fully normal behavior. This never happened in the evening when l left the work.
Any ideas? What could be the link between a dash instrument and the gearbox management? Current:
- L322 2006 S/C lpg
- RRC 1988 lpg / 287 000 miles
- Stage one 1981
- Lightweight 1976
- 109 SW 1968 under rebuilt
Gone: none
Post #368028 19th Jan 2016 9:33pm
Ian c2
United States 2007 Range Rover Supercharged 4.2 SC V8 Stornoway Grey
Iirc the box will hold gears longer defendant in temperature .
The engine coolant thermostat is also tested by timing how long it takes the engine to get to temperature *
Mine failed open and I got "check coolant level" messages after about 3 minutes as I recall .
* More like it sets a timer , and if the coolant is not up to temp by the end , it fails .
Post #368068 20th Jan 2016 3:28am
