Home > In Car Electronics (L322) > Rear Screens Feed
forever
Rear Screens Feed
Does anyone know what the input feed to the rear headrest screens are? I am wondering if i could intercept the feed in the seat and convert to standard RCA type plugs, i could then feed via a video out from a harddisk/pc for playing movies...
thx
Post #367953 19th Jan 2016 1:36pm
why not feed in from the aux video/audio sockets in the back,
Post #367956 19th Jan 2016 1:47pm
forever
I dont currently have that, i am looking at buying a set of front seats to replace mine that on the drivers side the heating has failed, much cheaper than the elements Smile.
For some reason the original purchaser of my vogue se had the RSE either not spec'ed or removed, the seats i have found that match mine all have the rear screen...
Post #367959 19th Jan 2016 2:00pm
forever
To add i think someone in the past has removed it rather than not getting spec'ed, as i have a hole in the rear left where the dvd player should be, i also have a hole where you took that picture Stan, looks like someone removed the whole lower part of the console, why i have not idea..
Post #367966 19th Jan 2016 2:40pm
when you get the seats have a look underneath them and there should be a plug/socket that you could tap into... ... - .- -.
Post #367971 19th Jan 2016 2:55pm
forever
Thanks hoping it's straight forward I see no reason why not Smile
Post #367999 19th Jan 2016 6:44pm
Eric Cartman
Ireland 2010 Range Rover Autobiography TDV8 Santorini Black
the RSE module is cheap enough too, as is the IO unit. The dvd changer is the only really expensive part if you have the screens. You could leave that out and just use AV
Post #368017 19th Jan 2016 7:45pm
forever
So those parts are just plug and play? Not worried about the DVD side as all my films are on my NAS so would just copy some off onto a drive...
Post #368023 19th Jan 2016 8:11pm
Eric Cartman
CCF alteration to tell the head unit you have RSE but thats it.
http://www.disco3.co.uk/gallery/albums/use...0Guide.pdf
theres a guide from a disco but the rse module is the same. obviously you can leave out the dvd changer bits.
Post #368031 19th Jan 2016 8:48pm
forever
Thanks for the detail.
Post #368054 19th Jan 2016 10:13pm
