![]() | Home > Technical (L322) > Torque converter/gearbox issues on TD6 L322 |
Ian c2 Member Since: 19 May 2015 Location: Socal Posts: 217 ![]() ![]() ![]() |
Welcome to the forum Kim .
Andy3681 Member Since: 13 Jan 2012 Location: Newcastle under lyme/ Le Dorat Haute Vienne Posts: 912 ![]() ![]() ![]() |
Hello and welcome Kim.
gregdav Member Since: 26 May 2014 Location: just north of stafford Posts: 1077 ![]() ![]() ![]() |
+1 to the above. I would get the g/box refurbed before it goes bang!
"gm g/boxes" ....
^ The GM "box" used in the TD6 L322 was also used in the early X5 desiesel but it was designed for a medium sedan and is pants in a 4x4 because it has to work so far out of its designed parameters , not GM's fault really just BMW pushing their luck . 2008 MY Supercharged
Couldn't agree more.
docjones Member Since: 22 May 2013 Location: Helsinki Posts: 48 ![]() ![]() |
Any shudder when the LUC is engaged can also be due to imbalanced injectors.
cowman Member Since: 24 Jul 2013 Location: United Kingdom Posts: 186 ![]() ![]() ![]() |
i had the same problem in november ,mine was diagnosed as the torque converter ,i got a torque converter of ebay ,bmwe39man ,his name is doug he knows his stuff he recons them useing uprated plates and gives 2 yrs warranty give him a call great bloke to deal with. |
Doctor Foster Member Since: 18 Sep 2013 Location: Perth Posts: 9 ![]() ![]() ![]() |
I risked just getting the LUC replaced and a few months later had to return for a transmission rebuild, including the torque convertor again having to be opened up and cleaned out.
Totally agree. Mine had new valves, new clutch plates and two springs in the accumulaters.
