Home > Maintenance & Mods (L322) > Adaptive Damper Wire Service Fix (LR032839)
fatbob
Germany 2011 Range Rover Vogue 4.4 V8 Bournville
Hi All,
I have had the Adaptive Dynamics fault a couple of times on my RR, which I have fixed by stripping the wires back and then soldering and wrapping with heat shrink. The last time I really went to town and pretty much covered in heatshrink as far back as I could to try and offer a bit of protection to the really fragile wire. It seems that the white stripe on the multi couloured wire turns very fragile, shrinks then cracks and after a while the wire breaks.
I have found the part number LR032839 for the replacement, but had a couple of questions:
    1. Does anyone know of a reasonable seller that will ship to Germany?
    2. How far back do you take the original wire back to?
    3. Is it worth doing both sides at once?
    4. Is this replacement part of a recall?
Thanks for any help!
Post #367860 18th Jan 2016 9:20pm
Mr Tee
Just bought these from Dan @ Duckworths, complete kit with bullet connectors etc, was around £28, he will ship to you .you cut out a few inches, not part of a recal , although quite clearly very poor design!
Post #367885 18th Jan 2016 10:44pm
