Home > Maintenance & Mods (L322) > remote keys
neilokay
remote keys
Hi folks ,Got a problem with my keys. Went out to open my 2004 322 and the remote function has stopped working. Not done anything different to normal when parking it up the night before. Also the spare key doesn't work either. Tried a new battery in the key but no different. The car starts and runs as normal. Many thanks.
Post #367419 16th Jan 2016 7:12pm
http://www.fullfatrr.com/forum/topic32759.html?highlight=key+sync
Have a look at this, sounds like your keys have lost sync wth the car. Thumbs Up There is nothing that can't be fixed with a hammer😜😜
Post #367422 16th Jan 2016 7:18pm
neilokay
Many thanks for the speedy response but unfortunately after 30 or 40 attempts it still remains un-functional. I even tried disconnecting the battery for a couple of mins but to no avail. Could it be a unit gone down somewhere in the boot as there seems to be plenty to choose from.
Post #367479 17th Jan 2016 12:46am
You need a much longer battery disconnection than a couple of mins sir... You need either a couple of hours/overnight or look in the wiki (top right of this page) for a �hard battery reset process�
Post #367487 17th Jan 2016 1:53am
neilokay
Hi all. Tried the battery off again today for about 4 hours and still no joy. Looks like i'm gonna have to book her in somewhere.
Post #367697 18th Jan 2016 12:48am
neilokay
Also noticed that the doors don't lock when I drive off anymore. Tried the fuses in the boot but they're all fine. Slowly losing the will.
Post #367879 18th Jan 2016 11:28pm
Sounds like a problem with the locks rather than the remote then - at least you're narrowing it down.
Did you also check the fuses behind the glove box ?
Post #367883 18th Jan 2016 11:39pm
neilokay
Is there a locking module and if so where about is it located. I have checked the fuse in the boot and it is fine.
Post #368778 25th Jan 2016 1:28am
What about the fuses behind the glovebox? Are there any there that are relevant?
Post #368798 25th Jan 2016 11:25am
