Home > For Sale & Wanted > [For Sale] Testbook Diagnostics Kit
dhallworth
This might not be of interest to many on here, then again it might so here goes Smile
When we had 3 P38's, this was the handiest thing we've had in a long time. Now we're down to one it's not worth keeping, especially as this one has a valid Faultmate MSV2 Extreme dedicated to it.
We bought this about 4 years ago and haven't had a problem with it since. It comes with:
Freelander 1, Discovery 2, P38, MG/Rover, Rover, Testbook T1 Special, All LR/RR and a Testbook Back Up Disc.
Included is a Testbook Extension Lead, a Testbook Isolation Brick, along with the Red, Yellow, Green and Blue Testbook Cables. This kit will work on any MG/Rover/Land Rover up to 2005. The blue cable does all ECU's on Freelander 1's, Discovery 2's, and most ECU'S on a P38 with exception to the Air Suspension and Airbag ECU. These EAS and SRS cables aren't included but can be purchased online if required.
The red cable works on all L322's from 02 - 05. The yellow cable is for Rover 200 & 400, and I can't remember what the green cable is for I'm afraid. It's something on the Rover side of it!
I've also got the HP Deskjet Printer that goes with this. It comes complete with power supply and parallel cable, it does need a new ink tank though.
All of this kit is easily wheeled around the workshop on the Testbook trolley that comes with it. The trolley has been kept in the garage so is dusty and in need of a good clean. The Testbook unit itself has always been kept indoors and away from the damp. The power supply that is built into the trolley doesn't work but the Testbook does come with a separate power supply which has never given us any problems.
Price: £800 ono.
I'd rather this was collected due to the delicate nature of it, that way it can be demonstrated working as well Smile
2007 Range Rover Supercharged in Java Black with Ivory Leather
Post #353860 23rd Oct 2015 6:11pm
p38arover
Australia
Hi, I need to make up a red connector. Would you be able to photograph the connectors at each end so I can try to work out the pinouts?
Cheers,
Ron Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #367295 16th Jan 2016 5:56am
dhallworth
Unfortunately this has sold and I no longer have a red cable.
If you get in touch with these guys:
https://www.roverparts.com/Parts/DTC0065A
Although it shows out of stock on the website, if you get in touch with them they often have them in stock.
Post #367474 16th Jan 2016 11:09pm
p38arover
Australia
Thanks very much David Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #367729 18th Jan 2016 10:16am
