![]() | Home > Maintenance & Mods (L322) > Brake System Diagnosis, Parts, Labour on RR 08 & 09 |
Weejock Member Since: 30 Dec 2011 Location: UK Posts: 418 ![]() ![]() |
Follow the bedding in procedure here:
I doubt it would cause a huge issue if the discs were not cleaned off, its just best practice to clean them off if you want the brakes to work properly from the outset. The smoking is from the new pads, the final binding resins being cooked off when bedding in.
luv2xlr8 Member Since: 29 Mar 2015 Location: Dubai Posts: 57 ![]() ![]() ![]() |
thanks. |
Thanks guys, the braking is juddery, cant explain it, something like hicups. When I come to a stop i usually throw it to N . I hold the brake then to D and as i lift my foot of the brake, not smooth flowing, its like im trying to snatch something as I lift my foot of the brake, every now and then..hope that makes sense. Also when coming to a stop, i feel a lag or gap, like i need to press a little more than usual to feel in control of where I want to stop, finally when it stops, usually its firm and precise, feels like its a loose stop if that makes sense at all?
Attached |
turned out to be bushings..front arm and suspension bushings both sides changed..all nice and smooth now 👍🏼 |
