Home > Technical (L322) > Heated front screen - sort of...
Phil303
United Kingdom 2007 Range Rover Vogue SE 4.4 V8 Buckingham Blue
The passengers side of the heated windscreen clears really quickly but the driver's side not as much - if at all using the heated screen function.
Is the only fix a replacement screen?
Post #367202 15th Jan 2016 1:42pm
3528cc
United Kingdom 2008 Range Rover Autobiography 4.2 SC V8 Buckingham Blue
RR Classics has two fuses L & RH for the front screen, presume it is similar for L322's would check fuses firstly.
If it is clearing in bands could be an issue with the screen, replacement being the only oprtion Regards
Royston
2008 4.2 Supercharged Autobiography
1994 Classic Vogue SE
1999 Rover BRM
1987 Rover Vitesse Twin Plenum
Post #367205 15th Jan 2016 1:52pm
Ian c2
United States 2007 Range Rover Supercharged 4.2 SC V8 Stornoway Grey
I don't really know , but had my screen resealed last week and thought I saw connections on both sides .
If you pull off your interior a-pillar trim you can check and clean the connections .
I remember him pulling off the airbag badges but didn't see him remove the trims so can't help with that , although it's sure to be on this site somewhere !! Smile
Post #367209 15th Jan 2016 2:12pm
front windscreens do get condensation on them and if there is a connection on the drivers side then it could have got moisture in it causing a bad feed.. ... - .- -.
Post #367211 15th Jan 2016 2:15pm
steadyaway
Under the airbag badge is a screw (torx I think). Undo this and the trim just unclips.
Post #367262 15th Jan 2016 8:11pm
