![]() | Home > General > 'Normal' Drive (auto) vs Sport (S) auto? Differences? |
cliff5.0sc Member Since: 29 Dec 2015 Location: USA Posts: 137 ![]() |
The 4.4 tdv8 has an 8speed which I do not know of. The ZF 6hp26 and 6hp28 are what I am familiar with. The zf 6 speed has two drive modes and sport modes which is dependent on how you are driving, there is a sporty normal mode and a normal sport mode (not right syntax -- I'll find the official document) that automatically select based on your throttle input and jerk. Still looking for the document on land rover document of the different zf modes, but I believe someone copied some of it here: http://www.rangerovers.net/forum/6-range-r...post389376 |
horse86 Member Since: 09 Dec 2014 Location: PA Posts: 863 ![]() ![]() ![]() |
I'm getting a steady 16mpg US on my 4.4NA jag engine. My drive is almost all highway and I have it in normal mode. If I Put in in sport @ around 70mph and bump it into Normal the RPMs significantly drop (like an overdrive gear would). My RPMs basically stay around 2k in normal drive on the highway. This would almost certainly mean sport would get worse on the highway...it would have to with higher RPMs.
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2272 ![]() ![]() ![]() |
I drive mine in sport most of the time and get about 15 to 16 mpg in a s/c so not bad |
When you first switch it is different than driving in that mode for a while. If you are in normal and switch to sport mine often downshifts immediately. Sport mode isn't in itself a sixth gear inhibitor, sport normal mode will shift into sixth, super sport mode (when you are driving hard or cornering) will inhibit sixth gear. If you are driving gently you can cruise in sport mode and engage sixth gear. Here is some info from jag forum: http://www.jaguarforum.com/showthread.php?...post754797 Last edited by cliff5.0sc on 14th Jan 2016 5:36pm. Edited 2 times in total |
Good man! 4.2 or 5.0? |
Unfortunately only a 4.2 and 6 months till I upgrade |
4.2SC is one of the best engines in a RR imo. 5.0 is fantastic engine too, maybe a bit rougher or louder at idle imo. |
Mine has done 122k miles of which I have done 62k in just over 2 years and it has been fantastic |
nemesisdazza Member Since: 20 May 2015 Location: South East Posts: 76 ![]() ![]() ![]() |
I just drove to Manchester and back in my 5.0 SC in Sport mode and averaged 18 MPG so I am happy with that!!! |
Doing that same journey on Monday so will have a little look and see what we get |
