Home > Maintenance & Mods (L322) > Coolant Low
tb10
England 2005 Range Rover Vogue 4.4 V8 Tonga Green
Joe90 wrote:
@ tb10
Sounds like a thermostat problem. Needle should be rock solid at halfway.
Hey Joe90,
Thanks for that. It may be the wiring in that case. I'll check it. It was rock solid before the coolant departed!! Confused
Thanks again! Thumbs Up
regards
John
Post #366612 11th Jan 2016 10:51pm
supershuttle
Just pumped most of the water out, conveniently (as I haven't driven it) it was still sitting above the rest of the coolant and refilled with 50:50 mix. No water under the car this morning soi I'll just keep an eye on things and see how it goes its probably not quite 50:50 overall as there was a bit of water I couldn't get too but I don't really need protection down to -32F Rolling with laughter Geoff
Post #366811 13th Jan 2016 10:58am
RaveRover
Australia 2005 Range Rover HSE 4.4 V8 Java Black
Hey.
No one here has mentioned using 'Deionised water' or distilled water in their radiators. I am currently trying to get a warranty claim thru on my Hella BEHR radiator that has started leaking after 13 months. Always used Nulon and mixed between 33% and 50% concentration.
There's talk of 'stray current / voltage' or using tap water instead of distilled water.. really, how important is it and could this make it fail after only a year? Anyone else had a similar prob?
Thanx Matt Once you've driven a Range Rover, everything else seems 2nd rate.. Eeeek I'm trapped for life.
1986 RRC Highline with offroad mods. Arctic Silver
2001 P38 HSE. Ardeness Green.
1995 RRC soft dash (beautiful car) Green.
2005 L322 HSE V8. - Current, most awesome car yet. And most expensive.
Post #481874 26th Jun 2018 3:22am
Baltic Blue
Geoff,
A little tip from our friend Nino.
The float switch monitors coolant level and specific gravity.
Thus if the SG falls it reports low level, ie when you top it up with pure water even if the level is correct it still alarms.
Post #481876 26th Jun 2018 7:47am
supershuttle
Mine turned out to be the pipe that runs front to back in the "valley" between cylinders. Got it fixed but it wasn't cheap. Geoff
Post #481877 26th Jun 2018 7:54am
nino_nino
RaveRover, use of distilled water is primarily to prevent buildup of calcium deposit in the cooling system. use tap water in emergency only and reflush system as soon as possible. Thumbs Up
Nino,
Post #481887 26th Jun 2018 10:38am
