Home > Maintenance & Mods (L322) > Coolant Low
supershuttle
Coolant Low
That was the message I got this morning when I jumped in my car, although I topped it up I used water and it used a bit more than I thought it would, maybe a couple of litres or so. Obviously the antifreeze mix is now slightly compromised, I'll get some antifreeze and I'll pop some of that in when/if it goes low again. Anything to watch out for? Is it just standard antifreeze? Geoff
Post #366527 11th Jan 2016 1:51pm
tb10
England 2005 Range Rover Vogue 4.4 V8 Tonga Green
I had this very issue last week and when i topped up the water it then poured out from underneath. Shocked At first I thought it was the water cooled alternator and was ready to replace it but when I was removing the viscous fan, water came out of the thermostat pipe and that was the proble. As small leak that developed very quickly into a rather large leak. I've put a new seal on the pipe and also siliconed it in place for goo measure!
The odd thing is that for the first time since buying the car (in a year) the car now runs cool so I'm wondering if I have damaged or inadvertently repaired something? The temp gauge used to be permanantly at half way and now it moves between cool and almost half way if in traffic?
Any ideas?
As for your question Geoff, any leaks from any pipes as mine was originally?
regards
John
Post #366539 11th Jan 2016 3:40pm
supershuttle
I would normally look under the car to see if anything appearing on a dry drive, but for obvious reasons this hasn't been possible recently. I will keep an eye on the level but in the meantime, what sort of antifreeze and what concentration? Geoff
Post #366540 11th Jan 2016 3:47pm
supershuttle
BTW, my temp gauge gets up to the mid point after warming up and stays there. Geoff
Post #366541 11th Jan 2016 3:48pm
i suspect its the mixture geoff,
this is from the owners manual,
Post #366542 11th Jan 2016 3:57pm
and this is from the wiki, doesnt list the 5.0 but it should be the same as the 4.2..
http://www.fullfatrr.com/wiki/Recommended_Lubricants ... - .- -.
Post #366543 11th Jan 2016 4:01pm
2010 -> handbook lists Castrol SF antifreeze 50:50 mix, which is basically a PINK coolant. I have always used the pink silicate free halfords stuff, which is also an OAT coolant like the SF.
Finding the SF is like finding hens teeth so most garages just use whatever pink is available, the coolant is the same in the 4.4 and 3.6 diesels too (for ref) There is nothing that can't be fixed with a hammer😜😜
Post #366550 11th Jan 2016 4:37pm
whats the difference between the orange recommended in the owners handbook and the pink one. ... - .- -.
Post #366558 11th Jan 2016 5:11pm
Beach
United Kingdom 2016 Range Rover Autobiography 5.0 SC V8 Barolo Black
I see you have 5.0 SC like myself, keep an eye on level as mine needed new water pump and plastic pipes replaced to sort it out. Have a feel of water pump pulley for play or while engine running you can see the pulley wobble. From what i found out there common problems on this engine.
Post #366562 11th Jan 2016 5:30pm
Zirconblue
Not a lot.
There are basically two types of coolant, Green/Blue and Pink/Orange, so long as you don't mix the two types they can be considered the same, the only reason they handbook mentions Orange is to differentiate it from Blue/Green, once its in the car it's often difficult to tell the difference between Pink and Orange anyway.
You can actually use either type in any engine, providing it says it's for mixed metal engines and you don't mix the two different types. The only real difference 'in practice' is the Pink/Orange lasts longer, so you don't have to replace it so often. So if you changed to Blue/Green you'd have to ignore the vehicle manufacturers change interval, and do it more often.
All this fuss about using the 'correct' coolant (on most car forums), is a historic thing, years ago the majority of cooling systems were iron (block, water pump, thermostat housing etc) with a Brass radiator. When they started fitting engines with ally bits in the cooling system the old coolants of the time didn't stop the ally corroding, so you got bi metal corrosion and all sorts. These days all engines are mixed metal one way or another, so all coolants are compatible with all engines.
Post #366576 11th Jan 2016 7:08pm
supershuttle
So its not green, not blue but red at £5 a litre I'll get some and see how it goes
 Geoff
Post #366590 11th Jan 2016 8:20pm
Laughing trust you to get yet another colour coolant .. ... - .- -.
Post #366599 11th Jan 2016 9:29pm
got a 5L tub of that in the garage, used it on the 3.6, didn't have any problems when I owned it. ECP do it.
Its fairly pink when diluted Rolling Eyes There is nothing that can't be fixed with a hammer😜😜
Post #366601 11th Jan 2016 9:47pm
@ tb10
Sounds like a thermostat problem. Needle should be rock solid at halfway. .
Post #366603 11th Jan 2016 9:59pm
Zirconblue
Yep, the ready mixed is more or less the same price comparing like for like. ie. 10 litres of ready mixed costs about the same as 5 litres of concentrate. I went with ready mixed just for convenience.
Post #366608 11th Jan 2016 10:28pm
