Home > Wheels & Tyres > 18" RRS wheels onto 2004 L322
p38arover
Australia
I have these 18" RRS wheels that were on my P38A and am thinking of fitting them to my L322 when I go bush instead of running the 20" rims.
Unlike the 18"x7.5" rims specified tyre placard on the RH B pillar, these are 8" wide with 53mm offset (8Jx18EH2+53)
They are labelled RRC505360XXX 940kg load rating.
Would anyone know any reason why they wouldn't be OK? (I haven't pulled a 20" rim off yet to check its load rating.)
EDIT: corrected part no. Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #364629 31st Dec 2015 10:33am
The 19" wheels off my old 3.6 which are now on my disco, have the following markings
might help.
I would take one of your wheels off to check clearances on the callipers with the 18" on as it can be tight and is a no go if you have brembos, which is unlikely on a 04..... There is nothing that can't be fixed with a hammer😜😜
Post #366116 8th Jan 2016 5:13pm
chex
Kenya
You need to use RRS wheel nuts, L322 ones won't fit. 2004 L322 V8
Post #366180 9th Jan 2016 5:55am
p38arover
Australia
Yep. I have the RRS nuts I used with the P38A. I must admit that's annoying as I'd like to get rid of the locknuts from the L322 and had hoped to use the RRS nuts. It looks like I'll have to buy 4 nuts. Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #366181 9th Jan 2016 5:58am
p38arover
Australia
Well, I got around to trying them tonight. They seem to fit OK. I'm pretty sure the bore size is the same - I checked with verniers and internal expanding bore gauges - 72.5 or 72.6mm
The only problem I can see is the OD of the 255/55R18 tyres on the RRS rims, while being the same as the P38A 255/65R16 tyres at 29", is 1" smaller than the 255/50R20 tyres (30" OD) the L322 currently has fitted.
That's about 3.4% smaller. I can probably live with that until new tyres are needed when I could go for a 255/60R18 Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #381424 9th Apr 2016 12:57pm
wayneg
Australia 2007 Range Rover Vogue SE TDV8 Java Black
When you decide to change the 18" tyres give some thought to 265 60 18`s. I run 19" in town but swap to the 18" when out. The 265 60 18`s are fitted to loads of Hi lux, Prado`s and Land Cruisers so are readily available. There are loads second hand in the small adds as the Cruiser guys want bigger. I got a set of 4 nearly new Dunlop Grand Trek AT 22`s for $150. The AT 22`s have a stronger sidewall than the AT20`s but look the same so good for the bush on low pressures 2007 TDV8 VSE
2003 TD6 gone.
2002 P38a gone
1999 P38a gone
1997 p38a gone
1993 VSE gone
1992 VSE gone
1966 Series 2a with V8 conversion gone
Post #381550 10th Apr 2016 1:16am
p38arover
Australia
Thanks Wayne, will do. Did you find them in the local paper, on Gumtree, or eBay? Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #381553 10th Apr 2016 5:20am
wayneg
Gumtree, I seem to do well buying and selling stuff on Gumtree. Found my TD6 on there too. 2007 TDV8 VSE
2003 TD6 gone.
2002 P38a gone
1999 P38a gone
1997 p38a gone
1993 VSE gone
1992 VSE gone
Post #381556 10th Apr 2016 6:15am
p38arover
Australia
I'll have to try Gumtree. eBay's fees are a bit rich. Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #381558 10th Apr 2016 7:01am
miggit
Standard tyre size for the ffrr on 18's is 255/60r18 so we are talking 5% of 255mm difference in height.... that's 1/2 an inch or 12.5 mm nothing if you change all the wheels Very Happy
I have a pal who brought a ffrr with 255/55/18's on it and it doesn't hang around... in fact it accelerates better Thumbs Up Yesterday I couldn't spell Engineer... Today I are one!
Post #381568 10th Apr 2016 7:49am
