Home > Maintenance & Mods (L322) > Transmission oil change |
vaz Member Since: 15 Jun 2014 Location: Colne, Lancashire Posts: 332 |
Just going through a to do list of our recent new motor and top of the list is all the oils.
6th Jan 2016 8:25pm |
kmhphoto Member Since: 01 May 2011 Location: London Posts: 7 |
Would this be the same thing?
7th Jan 2016 2:11pm |
Ian c2 Member Since: 19 May 2015 Location: Socal Posts: 217 |
http://www.zftranspart.com/index.php?p=cat...8&pg=1 |
7th Jan 2016 3:17pm |
Lost for Words Member Since: 18 Jun 2015 Location: Warminster, Wiltshire Posts: 473 |
http://www.advancedfactors.co.uk/tyk500050...-174-p.asp Visiting from DISCO3.CO.UK
7th Jan 2016 3:20pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35331 |
^ site sponsor as well... ... - .- -.
7th Jan 2016 3:22pm |
Well my source has none in stock, it was Jpat who had an autumn flyer with a special offer for 20 litres. I emailed them on Tuesday and they have none left, only 1 litre or 309 litre drums.
8th Jan 2016 5:05pm |
cam-tec-craig did mine and he replaced it with a genuine one which is made of a hard plastic.. ... - .- -.
8th Jan 2016 5:10pm |
Mightymarcos Member Since: 24 May 2015 Location: Alvechurch, near Birmingham Posts: 31 |
Changed mine over the Christmas break using an OEM plastic pan which was almost half the price of a non-genuine metal pan conversion. On the basis I am unlikely the do this more than twice while I own the car, I went for the OEM plastic part and it was a doddle.
8th Jan 2016 5:44pm |
Hi steve .
8th Jan 2016 5:57pm |
Thanks for all the info.
8th Jan 2016 8:07pm |
It is. Steve @ Advanced has researched the matter, and that is the same as Lifeguard 6 in a different bottle. Also recommended by flushing gurus Disco_Mikey and geoff. on Disco3. Re the sump, my view on the matter is to stick with the plastic one - as the metal one holds slightly less fluid and it's also been reported that it's harder to get a good seal. Since the filter itself does so little (the fresh oil is the important bit), I'm not going to be that bothered about changing that early or often, so the plastic one isn't really a problem in that respect, IMO. Visiting from DISCO3.CO.UK Discovery 3 TDV6 Auto HSE Zambezi Silver |
9th Jan 2016 9:40am |
24th Jan 2016 2:27pm |
Full Fat Ray Member Since: 23 Jan 2014 Location: Cwm Llinau Posts: 574 |
Personally, I wouldn't put ANYTHING except for the correct grade of oil in your gearbox - you will be unable to get it all out again, and will therefore contaminate your new oil, as well as almost certainly causing damage to the internals of the gearbox.
25th Jan 2016 11:35am |
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 968 |
This whole issue of badged fluids confuses the heck out of me. Clearly ZF manufacture transmissions and not fluids and, if we take the 5-speed 5HP24 transmission as an example, in the early days ZF specified Esso ATF LT71141 as the only fluid suitable for the 5HP24 in their official ‘List of Lubricants’ TE ML-11.
25th Jan 2016 2:30pm |
