![]() | Home > In Car Electronics (L322) > Anyone fitted amateur radio gear in an L322? |
p38arover Member Since: 16 Dec 2015 Location: Western Sydney Posts: 1558 ![]() ![]() |
I'm looking to install my Alinco DR635 2m/70cm ham rig in the L322 but finding somewhere to do it might be an issue. I also want to fit my UHF CB radio in the vehicle.
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3255 ![]() ![]() ![]() |
Haven't tried it. Transmitting on HF unlocks the Disco 2 outside the house! |
Thanks John. I hadn't thought to look over at RRnet. As an ex-Admin from there, that's a bit embarrassing! Ron B. VK2OTC
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35632 ![]() ![]() |
there's a member here wayneg who has the mention of a UHF setup in his signature ..hopefully he will see this thread and comment.. ... - .- -.
littlecub Member Since: 02 Apr 2013 Location: Ulverstone,Tassie Posts: 327 ![]() ![]() ![]() |
Been wondering where I'm going to put mine.
Thanks Stan. I'll get onto Wayne. I know him from the AULRO forum (well, I haven't met him, he's on the other side of the country).
Ziggy Member Since: 26 Dec 2011 Location: West midlands UK /sydney AU Posts: 265 ![]() ![]() |
Couple of photos of the aerial mount using existing holes just increased the bolt length by 5mm
The radio you can just see the big bolt (existing) that the bracket is bolted to then the radio's bolted on the bracket power comes from the cig lighter in the center console It can all be removed leaving no trace of it ever having a UHF fitted Hope it helps Zigg "Those who cannot remember the past are condemned to repeat it." George Santayana Puts away his cloth cap and donkey jacket Goes and sits in the naughty corner |
Excellent, thanks Tony. Did you have to adjust the bonnet catch? I like the bracket, I didn't want a bracket to exit through the grille.
This method might be a possibility. Sorry about the quality but I saw this at the LR 60th Anniversary in Cooma in 2008. It was on the tailgate of an RRS.
2003 L322 V8 Auto 2007 Yamaha XJR1300 Previous: 1983, 1986 RRC; 1995, 1996 P38A; 1995 Disco1; 1984 V8 County 110; Series IIA |
No worries Ron
Unfortunately I left the sunnies holder in the P38A when I sold it. I didn't realise until until the buyer asked what it was (it was a genuine LR accessory that screwed on where the Driver's side hand hold would have fitted above the door). Ron B. VK2OTC
Edfors Member Since: 26 Oct 2012 Location: Uppsala Posts: 168 ![]() ![]() ![]() |
Interesting, been thinking about how to fit a radio on EDF, but SWMBO don't like the idea as much, must be a way where it's not intrusive in any way. And the antenna has to work in low ceiling parking garages as well. Look forward to see more ideas about installations. Supporter and maintainer of EDF - Mrs Edfors' shopping cart. |
What sort of radio are you looking to fit?
Well, no need for a full amateur rig really, since the L322 is what she drives most, there is no other need than 27 Mhz, which the local and national LR clubs use here, I can have whatever other stuff in my Discoverys, so this limits it some and then it must have other features like green background illumination and as said as small as possible, but the most limiting factor is Auto Squelch. So this has limited me to look at the President products. Grant II ASC or Lincoln II ASC. If I could get away without the ASC I would go for the spare Alan 42 I have in the garage.
sako243 Member Since: 26 Dec 2013 Location: Wales Posts: 613 ![]() ![]() ![]() |
Not HF but I've fitted both a CB and VHF set to mine - both easily removable.
