Home > Technical (L405) > DAYTIME RUNNING LIGHT
WBSam
United Kingdom 2013 Range Rover Vogue TDV6 Loire Blue
Please I just got a 2013 VOGUE but i have not driven it as i have to travel immediately. I noticed the Daytime runninglight was not on. i tried to find the setting but couldnt locate it. Can anyone advise on how to set it as that is one of my most admired features of the car
Post #365239 4th Jan 2016 1:40pm
Pfazz
2019 Range Rover Autobiography SDV8 Loire Blue
On the 2016 model you need to have auto lamps selected on the lighting stalk for them to work but they can also be disabled or enabled by the dealer. Not sure about earlier ones tho. Agueroooooooooo. 93-20
I swear you will never see anything like this ever again....watch it..drink it in.
Post #365244 4th Jan 2016 2:23pm
Pfazz
EXTERIOR LIGHTS Go to previous page
DAYTIME RUNNING LAMPS
With the lighting control in the OFF position, Daytime running lamps will switch on automatically under the following conditions:
The engine is running.
The gear selector is not in Park (P).
The Electric Parking Brake (EPB) is not applied (released) - market dependent.
Auto lamps are selected and high ambient light levels are detected.
Unless required or prohibited by law, Daytime running lamps can be disabled or enabled by a Retailer/Authorised Repairer Agueroooooooooo. 93-20
Post #365245 4th Jan 2016 2:26pm
WBSam
Thank you. will check it when i return
Post #365571 5th Jan 2016 11:59pm
Autobiography
2018 Range Rover SVAutobiography 5.0 SC V8 Santorini Black
DRLs cannot be disabled in the UK by law.
Post #365617 6th Jan 2016 11:49am
Pfazz
The above was a proviso in my answer to the OP. Agueroooooooooo. 93-20
Post #365633 6th Jan 2016 1:25pm
oldcro
United Kingdom 2012 Range Rover Westminster 4.4 V8 Stornoway Grey
The only law I can find states that DRL's must be fitted to cars built after 2010. My car a 2015 model has them and comes with the option to select them on or off.
Post #365693 6th Jan 2016 5:24pm
JasM
Scotland 2014 Range Rover Autobiography SDV8 Santorini Black
I think DRL's are an optional extra on the Vogue models. 2014 SDV8 Autobiography Cool
Gone: 2012 RRS SDV6 HSE, 2007 RRS TDV6 HSE
Post #365700 6th Jan 2016 5:31pm
Pixelpower
United Kingdom 2005 Range Rover Vogue Td6 Santorini Black
No, they're standard
Post #365822 7th Jan 2016 9:28am
