![]() | Home > Technical (L322) > Strange Starting Issue |
I think you may need to change your secondary fuel pump. |
Nicka2311 Member Since: 29 Dec 2012 Location: Scotland Posts: 51 ![]() ![]() ![]() |
It was the secondary pump that I replaced under the N/S/R wheel. That's why I'm thinking something causing a pressure loss in the fuel system and going for a fuel system cleaner and probably a few tanks of Ultimate diesel afterwards. '55 Java Black Vogue |
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1816 ![]() ![]() |
It sounds as though you have a faulty injector. You need to have an injector leak off test carried out to determine which (indeed, if any) injectors are at fault |
Thanks Mikey,
As you have changed the secondary fuel pump, presumably for a reputable make, have you considered the fuel pump relay causing problems. The fuel pump relay is located on the rear fuse board and serves both the intank fuel pump and the secondary fuel pump. It might be worth swapping the relay to see what happens. |
I've got a spare LR relay in the car, which relay is it exactly don't have an owners book to help out so will swap it out for testings sake but it seems like there is fuel, just a pressure issue, unless there is some sort of strange resistance issue in the relay not allowing enough power to the pump to maximise pressure???
If the relay is at fault i would suspect burnt contacts, they don't last for ever.
