Home > Technical (L405) > INFO REGARDING ARCAN JACK PLEASE
Basilfawlty
England 2016 Range Rover Autobiography SDV8 Corris Grey
Pretty much as the the post title. I've just bought a Arcan 2000KG (HJ2000EU) trolley jack from Costco but now I've got it home I'm just wondering if it's right for the car.
I realise my car weighs more than 2000KG but my thoughts were that I'm only raising one side but is this right? and second it says the max lift is 470mm but is this enough for a full fat?
I'd appreciate your thoughts Thumbs Up
Post #365057 3rd Jan 2016 1:45pm
RRVSE
United Kingdom 2013 Range Rover Vogue SDV8 Corris Grey
I've been looking at that myself in Costco, I'm of the same belief as you, if I'm only jacking up a corner of the car , I'm assuming the 2 tonne jack will be fine. I used the RR jack a few months ago and for whatever reason, the scissor jack was fighting going up to the point where the winding handle buckled under the force I had to user. LR replaced the whole jack for me but since then I have been considering that jack as it seems well buold and is great value at �90. I also noticed what appear to be lifting points under the car (4 round metal discs, presumably for use when on ramps in the dealers? Steve
Main car : FFRR L405 Vogue SDV8
Other car : Vauxhall Lotus Carlton
Past cars : FFRR L322 Vogue TD6 SE (Sept 2006 MY07) ; LandCruiser SWB ; 4-Runner ; Supras; XJS V12 LeMans
Post #365187 4th Jan 2016 2:58am
Basilfawlty
Thanks Steve, I'll make some more enquiries and if I can get a result I'll come back to you. Cheers Steve
Post #365199 4th Jan 2016 8:54am
Pfazz
2019 Range Rover Autobiography SDV8 Loire Blue
https://www.machinemart.co.uk/p/ctj3000ql-...trolley-j/
I bought this one and seems a good buy for a 3 ton high lift. Agueroooooooooo. 93-20
I swear you will never see anything like this ever again....watch it..drink it in.
Post #365208 4th Jan 2016 10:19am
