![]() | Home > Technical (L322) > Airbag Fault |
PaulB Member Since: 17 Jul 2011 Location: Hampton Posts: 877 ![]() ![]() |
Ian, thats a seat belt fault not an air bag.
ije44 Member Since: 01 Sep 2015 Location: Leicester Posts: 133 ![]() ![]() ![]() |
PaulB - Thanks for the reply. I assumed that the airbag and seatbelt system were connected and shared the same warning light. I will do the check though.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35622 ![]() ![]() |
you dont have to remove the seat, just slide it back and forth... ... - .- -.
Thanks Stan - I had a quick look under the seat earlier when it was light and there wasn't any clearance to be able to see anything, so sliding the seat is a job for tomorrow.
its for the transport mode, when the mechanics do the pdi.. ... - .- -.
Issue resolved.
rar110 Member Since: 09 Aug 2014 Location: Brisbane, Australia Posts: 1119 ![]() ![]() ![]() |
I had this same fault. I did the same as Ian. Seat full forward and back, restart, fault gone.
rar110,
thanks Ian, especially for the solution.
The forum in action!!! |
Looks like I'm not as lucky as you Ian. The warning light is back and won't go away after I put the seat forward to do some vacuuming. I might have to in bolt the seat to try to fix the loose connection. ______________________________
Today I did some fiddling around under the driver seat and spotted what looks like the seatbelt pre tensioner, that appears to be a small motor to pull or tension the seatbelt. I wiggled the two wires going into the motor and eventually the fault in the dash disappeared. Here's a couple of pics of the motor.
Vogue tdv8 08MY poverty pack - wow |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6419 ![]() ![]() |
Nice to see the photos are suitably orientated for antipodean use |
It's definitely what we thought then. Nice to know if the problem returns and it's exact location.
