![]() | Home > Technical (L322) > Rear suspension dropped on return from holiday!! |
Start looking for leaks in all heights , continuously running the compressor because you have a leak somewhere will quickly knacker it . 2008 MY Supercharged
dvb247 Member Since: 22 Nov 2015 Location: Cheshire Posts: 93 ![]() ![]() ![]() |
Would there be a hissing sound?
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35647 ![]() ![]() |
could be a small pin prick, use very soapy water when in off road height.. ... - .- -.
where? round the compressor in the boot? |
the four airbags.... ... - .- -.
will do Stan thanks, you don't suspect the new compressor fitting then? |
could be anything thats leaking..start at the airbags and work your way back [pipe work/air tank under car] to the compressor.. ... - .- -.
