![]() | Home > Technical (L322) > jesus another problem |
MachineHead Member Since: 20 Apr 2014 Location: The hoose Posts: 310 ![]() ![]() ![]() |
Any lights or warning messages?
thegamekeeper Member Since: 12 Nov 2015 Location: sunderland Posts: 71 ![]() ![]() |
no mate no warning lights or messages at all. i was pulling a trailer (empty) and there was a plume of white smoke when i stopped. it went away on tickover but when i drove it got heavier which makes me thinks its the turbo when theres a bit of presure on it. theres no rattles or nothing |
Black smoke is often a sign of the intercooler hoses, worth pulling them off and checking, very very easy to do a jubilee clip at either end to loosen and then just wiggle them off. I thought they might be hard to get off but I took mine off today very easily. Honest a ten minute job at most.
its more of a white smoke which smells oily. dont know if this helps but mines a td6 |
Mine is the tdv8 but the issue is pretty much the same regardless.
i will check the hoses first thing in the morning and fingers crossed its that. would that cause the oily smelling white smoke tho |
yes, split hoses often cause a smokey running engine and not always black, size of the split would probably have a lot to do with it.
thanks very much for that i will check them tomorrow. ive also been told the crankcase breather is also an issue and should be changed as this can also cause smoke |
yes I've heard that too, hope you find the issue |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7998 ![]() ![]() ![]() |
Turbo/Intercooler hoses is a common issue on the 3.6 TDV8 and results in lots go black smoke on acceleration.
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2035 ![]() ![]() ![]() |
i would warn against driving it, untill you have sorted it. if you have an oil burning engine, it can 'run-away' and over revv, and 'blow up' as you cant stop it. search youtube for turbo runaway, or 'diesel runaway' if it was to happen switching off doesnt stop it, and you cant stall it if its auto, so you have to get the bonnet up, and stuff a t shirt into the air intake, to suffocate it. with it revving at 5000rpm. |
yeah i heard about them blowin up and watched one do it on youtube. bloody scary that mind. need to check a few things tomorrow. hope i can sort it as ive just spent a fortune on 22s. new badges. full window tinting and much more. ive got it looking fantastic now and i cant drive the |
On the v8's they often have rotten pcl systems, and burn the oil that is leaked through. I'm sure the diesels have the same. Not expensive. The v8 you can buy just the failed diaphragm for about £20
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3661 ![]() ![]() |
AS Alistair said, crank case breather filter is the commonest cause of smoke on the BMW TD6 engine, as cheep as chips to buy and easy peasy to change, shouldn't take more than half an hour.
