![]() | Home > Maintenance & Mods (L322) > Sidesteps and Chrome Accessories |
Depends if they have been put on with silicone which can come off with a bit of elbow grease , if he has used some other serious glue then it could cause harm to the paintwork,
Those are two things that often don't go well together. ![]() |
Dan Member Since: 17 Nov 2010 Location: London Posts: 2 ![]() ![]() |
Thanks Mick. They are after market ones from a company called Famous Four in Lincs. If they have used a serious adhesive, and it is impossible to tell. The chrome looks as though it has been attached professionally-i.e. not a DIY job. Could I have the chrome mirror covers removed, and, if damage has been caused to the paintwork, buy some colour-coded mirror covers and attach them in their place? |
They are usually glued on with 3M strip adhesive. Try using a hairdryer to heat the area and soften the glue whilst gently teasing the part away from the vehicle |
As John above said ........... |
Another method is very hot water poured over the offending item, not boiling but almost |
