Home > Maintenance & Mods (L405) > wheel lifting straps
philbathurst
United Kingdom 2016 Range Rover Vogue SE TDV6 Montalcino Red
ordered full size spare wheel - it states in brochure that this option includes the straps & tools
"Full size spare wheel (includes toolkit and spare wheel lift assist)"
can't find the straps & can only see wheel brace & jack, not sure what other tools they mean
asked dealer to clarify
anyone had similar issue ? various other LR's this one is still the best
Post #362594 17th Dec 2015 10:38am
Should be in a little black bag somewhere in the wheel well - it's kind of a hoist system
Post #362595 17th Dec 2015 10:40am
martinf
United Kingdom 2016 Range Rover Vogue TDV6 Santorini Black
I have not found a little black bag in mine, either
Post #362616 17th Dec 2015 3:13pm
Pfazz
2019 Range Rover Autobiography SDV8 Loire Blue
If you have not got one it would be best to speak to the dealer because lifting the full size 22" spare out without it would be near impossible. Agueroooooooooo. 93-20
I swear you will never see anything like this ever again....watch it..drink it in.
Post #362619 17th Dec 2015 4:00pm
The kit only comes with the fill size spare - maybe even only with 22's - I'm not completely certain
Check with the supplying dealer as it's quite an expensive extra for what it is IMHO - details
Post #362625 17th Dec 2015 4:56pm
Doodle
Even if you order a spare wheel with L405, the lifting bag is not include with Vogue or SE in V6 or V8 form.
Only included with AB.
I spent a shed load on extras on my first 405SE SDV8 including FS spare, but no lifting strap. It's stingy and daft not to include it with the wheel.
Dealer said LR logic is that you would call out a breakdown service instead, rather than maul about.
However, when it comes carrying out work at home, then that logic is gone.
Moved to AB just to get the BLACK BAG. Laughing
Post #363319 21st Dec 2015 6:13pm
Giantlandyman
United Kingdom 2012 Range Rover Autobiography TDV8 Santorini Black
I've just ordered the spare wheel lifting kit from Dan (?) at Duckworths; it wasn't expensive. My car has a 20" spare but it looks like a second hand alloy bought by the owner rather than a factory option which is why the kit wasn't present.
There is the type pictured in the post above and there is another type that uses the lower tailgate and a cradle arrangement to lift and pull the wheel out. It is this kit that I have ordered.
Edit: This kit
Post #363329 21st Dec 2015 7:12pm
Is yours is an L322 - that kit doesn't work on the L405 - probably due to the powered tailgate
Post #363338 21st Dec 2015 7:50pm
Giantlandyman
I was fairly sure Dan mentioned in passing there was a 405 version but now I am beginning to doubt myself.
Post #363343 21st Dec 2015 8:20pm
carlos50
United Kingdom 2015 Range Rover Autobiography 5.0 SC V8 Santorini Black
Mine has the black bag, 13 plate SDV8 VSE with 21" wheels and full size spare. I had a flat recently and called recovery, these wheels are mega heavy and once out if the car was still a pain to get on without crawling around on the floor
Post #363398 21st Dec 2015 11:24pm
philbathurst
hopefully a result
Supplying dealer Stratstone has rung to say that I as I had the optional full size spare wheel 20" the lifting assist strap/kit/thingy should have come with it , he apologised and said he would order one it should arrive after christmas Thumbs Up
so if you have the space saver you don't get a lifting kit - how lighter is the space saver ? various other LR's this one is still the best
Post #363436 22nd Dec 2015 10:10am
philbathurst
Dealer has supplied mine in the post
noticed this in Topix
Q554 - Spare Wheel Lift Assist Strap Missing
so it looks like LR have identified the issue various other LR's this one is still the best
Post #364509 30th Dec 2015 11:27am
