Home > Maintenance & Mods (L322) > Tick tick ticking - driving me bonkers!
Roystonh
Hello all
I've had all the post purchase jobs done on my 2011 AB and paid to have squeaks and rattles traced and silenced in the cockpit. However the dealer can't get rid of a ticking noise which seems to be coming from the air vents (both sides) on the dash. It's pretty silent up to 40 mph but then picks up ticking which increases in noise and frequency- worst at 60 mph +
Any ideas what it might be? The dealer stripped out the plastic under the outer windscreen to below bonnet - I can take it back at £110 per hour but wondered if there are any recommended people/garages on here who are good at locating rattles and dealing with them
Thanks and all the best, Roy 2005 L322 Vogue Gold gone
2006 L322 Vogue Black gone
2011 L322 Vogue Silver gone
2011 L322 Autobiography Black gone
2015 L405 Autobiography LWB Black gone
2019 L405 P400e Range Rover Autobiography LWB Eiger grey / black roof gone
2001 P38a 30th Anniversary Wimbledon Green gone
2019 L405 P525 Autobiography LWB British Racing Green
Post #345163 30th Aug 2015 7:32pm
Beach
United Kingdom 2016 Range Rover Autobiography 5.0 SC V8 Barolo Black
I have a 2010 I acquired recently, on the test drive I had a similar noise. Before I picked the car up they had put in a new O.E windscreen as they put the noise down to poorly fitted replacement screen that was not an O.E screen. Maybe worth checking
Post #345167 30th Aug 2015 7:45pm
Roystonh
Had a new LR OE screen fitted about three weeks ago - noise was there before it was changed but thanks for the idea 2005 L322 Vogue Gold gone
Post #345170 30th Aug 2015 7:53pm
Beach
OK, good luck tracking it down
Post #345172 30th Aug 2015 8:13pm
wokkadriver
United Kingdom 2010 Range Rover Vogue SE TDV8 Zermatt Silver
Might be a long shot but on a P38 I had a few years ago I had a similar annoying rattle from the vents which I tracked down to dried leaves in the air intakes. Bit of a faff getting into them through the plenum chamber but sooooo worth it in the end!
Post #345177 30th Aug 2015 8:48pm
Roystonh
Update -
Just had the windscreen lower plastic trim replaced by the dealer as it was warped to sort the problem but it's still ticking. It's from both air vents but now only appearing at over 50mph. I had a poke around the engine bay today and the plastic bit in the middle seems a bit loose and has a clip missing. Not sure if a replacement of this might do the trick. Any views/advice? Ta Roy
Post #364116 27th Dec 2015 4:30pm
Pfazz
2019 Range Rover Autobiography SDV8 Loire Blue
Is it possible you could fold a piece of soft cloth like towelling and trap it in place on the suspect plastic by trapping it in the bonnet closure, just to eliminate one possibility that it may be rattling. Agueroooooooooo. 93-20
I swear you will never see anything like this ever again....watch it..drink it in.
Post #364123 27th Dec 2015 5:43pm
Zirconblue
that's the Pollen filter access hatch. It looks like only one of the catches for it is located correctly.
Push the hatch in a bit, and use a small screw driver to lever up the catches so they sit in the groove on the front of the hatch like the others.
It might not be your problem, but it wont hurt to do it.
Post #364132 27th Dec 2015 6:20pm
Roystonh
Thanks for that - I will stuff a towel on it tomorrow as long as I don't cause any damage to the car .... Will then try to fix it with a screwdriver as suggested.
It's a bit difficult to get to as its right at the back of the engine bay. Will take it o
n a run to Ashford as finally getting to see Star Wars!
Will let you know how it goes, cheers. ;@) 2005 L322 Vogue Gold gone
Post #364141 27th Dec 2015 7:33pm
Zirconblue
standing on a tool box helps, dropping it to access height also helps.
i've got one of those 2ft high hop step things, which is really handy.
Post #364142 27th Dec 2015 7:41pm
And Star Wars is great too.... Wink There is nothing that can't be fixed with a hammer😜😜
Post #364145 27th Dec 2015 8:18pm
Ian c2
United States 2007 Range Rover Supercharged 4.2 SC V8 Stornoway Grey
When you say lower plastic trim , do you mean the cowl ?
If so, they broke it putting the cabin filter back in . Rolling Eyes
One way to find out if it's wind noise getting in is to tape everything with masking tape .
But I use 3m electrical splicing tape , as its black and doesn't look all that bad when you're driving around with it around your windscreen for months on end Laughing
Post #364166 28th Dec 2015 1:46am
Roystonh
Thanks for the tips guys. Looking forward to taping things up tomorrow morning to try it out. The car has had this annoying tapping sound since I had it 25k miles ago and it's the make or break weather I keep it or not and I really like the car so hope I can fix it. Shame the stealers didn't! 2005 L322 Vogue Gold gone
Post #364169 28th Dec 2015 2:36am
Ian c2
Just a thought ...
Does playing with the hvac controls make any difference ?
If you manually half-close the vents for instance .
Or if you close them completely can you then hear it through other vents ?
Does hitting the recirc button change it ?
Does sliding the center vent control between hot and cold change it ?
Does it go away when you only have air directed at your feet ??
I'm thinking there are a lot of solenoids closing vents etc behind there , and it will be a mechanical issue rather than electrical issue , but maybe you can find out exactly where it is by process of elimination .
Good luck with it , and don't let a minor irritation turn into an irrational thought process ....
Once I've cured all my wind noise problems by fitting a new cowl and complete windscreen trimmings , I'm expecting to hear more minor noises like you're experiencing !! Whistle
Post #364170 28th Dec 2015 2:47am
Ian c2
Just had a thought ...
It could well be the windscreen side-trims on the a pillar .
Tape them too !!!
What I did was tape everything , and the wind noise stopped .
So I untapped one at a time to find where it wa coming from .
Unfortunately , it was coming from everywhere Rolling Eyes
Post #364204 28th Dec 2015 12:24pm
