![]() | Home > In Car Electronics (L322) > USB/Aux/Bluetooth Retrofit for MOST systems |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3255 ![]() ![]() ![]() |
Umn0-Tech - http://umno-tech.com/catalog/product_info....cts_id=559
Elements connected to show the order of connection. Top right the interface with the supplied fibre optic cable in place. Top left the Bluetooth box. Middle right the auxiliary cable. Bottom the microphone.
Remove the small �barrel� protecting the fibre optic connections from the unit. The unit comes with two jumpers. They came set to �Auto� (see the Umno-Tech site for jumper locations) and I left them there with no problems.
INSTALLATION The first step is to remove the glove box. This is well covered here: http://www.roverupgrades.com/Range_Rover_MP3_Cd_Changer.html The photos are for the pre-touch screen but the removal of the glove box is the same for later models. With the glove box out remove the CD multi changer from its tray. From the rear of the CD changer remove the white plug carrying the fibre optic cables and the power lead. Remove the fibre optic plug from the white plug.
All the fibre optic plugs in the system have an arrow indicating the direction of travel. Carefully remove the �In� cable from the plug. It is easier to do this by peeling back the cloth protective covering on the cables to expose a length of them. This will also facility the placing of the interface unit. Do not remove the �out� cable. To remove the cable push the blue �pin� in the plug half way out and then, using a fine flat head screwdriver or similar, gently raise the lock tab on the side of the plug. This will allow the cable to be pulled free. Next take the plug in the supplied kit which has the attached fibre optic cable attached and insert that cable into the white plug from the CD changer thus replacing the cable you have just removed from it. Then put the optic cable you removed from the CD changer white plug into the �In� on the interface unit plug (the one that came with the kit which had the optic cable ready installed). To do this you will have to release the inner plug from the outer using the locking catch on the side and insert the optic cable as described above. Replace the white plug, complete with power supply lead, back into the CD changer. You are now ready to locate the unit. I put it under the CD changer as there is a convenient void there at the back of the glove box. It is at this point you will see if you have freed enough of the protective cover for convenience. I passed the cable with the interface plug between the CD player and the tray so that it exited in the void below the CD player. This enabled a convenient connection to the passenger side fuse box and also it meant that the unit was readily available if needed. Insert the fibre optic plug into the unit and make the power connection. I also wrapped the fibre optic cables which were still behind the CD player in fresh protection (foam sheet) Locaion
Connect the other elements. The unit can be used on its own but I have used the other elements � Aux cable, Bluetooth box , microphone and USB/ Aux extension � to try to make this as comprehensive as possible. USB/Aux Socket
SET-UP Prepare an USB stick formatted to FAT16 or FAT32 with ten tracks in MP3 format . With the unit powered up insert the USB and wait for ten seconds. I gave it a bit longer. This initiates the unit. Then insert a different USB stick with MP3 tracks and check that the unit is working. Replace the glove box. OPERATING The unit must have a FAT16 or FAT32 USB stick with at least one MP3 track inserted to be in line. Effectively the USB stick acts as a �switch� and, if removed, the MOST system reverts to standard and, after a short time, the CD player comes into line. When the new interface is in use (USB stick inserted) the car screen changes to show MP1 and, under it, MP4 buttons. �MP1� gives the tracks and folders on the USB stick. Switching to �MP4� switches to Bluetooth or Aux. For setting up I use CD selected on the touch screen To pair your smart phone insert an USB stick. Press button MP4. - Turn on Bluetooth function on your smartphone and start Bluetooth search. - Press and hold the button on the radio "Fast Forward" for more than 25 seconds to start the pairing process. Wait until BM1681 displayed -Confirm Connect - Connected << >> is displayed on the car speakers. Bluetooth connection is established. INFO: Only one Bluetooth device can be connected to the interface. (However, if you already have the LR Bluetooth interface, you can connect your smart phone to that, which gives your address book and hands free and, at the same time, you can connect your smart phone to the new interface to stream music from it. If you don�t have the LR Bluetooth then, from the Umno website, you can use the new interface for telephone calls via the pairing and using your phone to dial up calls then hands free). CD Player - Interface off line (USB stick removed)
USB music playing - Note which button is used
Aux/Bluetooth in line - Again note which button is used
I have not included a photo of the microphone as, other than when I tested it, I don't use it. A nice advantage with the system is that you can create folders (up to 15) on the USB stick which then show up on the screen and can be readily switched between. One point I would make is that there is a time lag between switching from CD player to the interface which should last about 10 seconds or so. Nonetheless it is much better IMO than the time taken to load MP3 CDs on the original player. Hope all that is clear. It is actually pretty easy to do if you follow the steps. You will see on the Umno-Tech site that there are cables expressly for iPhone. Also I ordered a 2 metre USB/Aux extension to allow me some flexibility in location. As I said, apologies for the photos. The video on the Umno-Tech link above shows how the screen appears in the various operating modes. Mark, the chap on the website responded quickly and clearly to e-mails asking for amplification on some points. He prefers e-mail as it makes it easier for him to translate into German rather than telephone. I am pleased with the system. It gave me what I wanted, namely the ability to play music from USB at much lower cost than the LR system. The Auxilliary and Bluetooth functions are there as a bonus if I wish to use them. I have no connection with the company other than as a customer. If you wish to dispense with the CD player then when you remove the white plug from the back of it you transfer the optic cables from it to the new interface (do one at a time so that you don't get mixed up between "IN" and "OUT" ![]() You can then use the power connection as well. John 2008 Stornoway Grey 3.6 Tdv8 Vogue - SOLD 2005 TD6 Java Black Vogue - Written off!! GAP iiD BT-Sold Last edited by Weegie on 23rd Dec 2015 5:23pm. Edited 4 times in total |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35622 ![]() ![]() |
great write John, thank you..
�229 plus postage a �14. The Bluetooth item is an additional �49. So total �292 or approx �216. John
my xmas money might be spent on that (maybe |
bebechoon Member Since: 22 Apr 2014 Location: In ze middle of Frainsch nul part Posts: 454 ![]() ![]() |
Yes, a great write-up, John. Thanks |
forever Member Since: 06 Oct 2015 Location: Oxted Posts: 319 ![]() ![]() |
Nice thanks.. |
Can't help with the wireless bluetooth. When streaming it from my phone I was only using what had already been loaded.
Ian c2 Member Since: 19 May 2015 Location: Socal Posts: 217 ![]() ![]() ![]() |
Thanks for the write-up .
I have just left it beside the interface in the back of the glove box as I have the LR bluetooth for telephone calls.
I have added some more photographs to my post. John
Now been using the interface for a few days and I have to say it does everything it promised.
Phillo Member Since: 01 Jan 2016 Location: Cornwall Posts: 6 ![]() ![]() ![]() |
Interesting post |
Now that I have had it operating for a week or so I am very pleased with it. Does everything I want
Thanks for the recap and added pointers, like you, playing music with quality sound is what I wanted, so looks like I will snap one of these units up and fit, handy to have your post as a guide. Cheers. |
