Home > Technical (L322) > Knocking/rattling noise coming from front suspension?
oodathort
how about disc back plates they rot around the fixing bolts then flap around
Post #97996 16th Dec 2011 2:18pm
rads
2005 Range Rover Vogue SE Supercharged Tonga Green
Mine is too heavy to be a disc back plate. Clunk, not rattle!
David
Post #97997 16th Dec 2011 2:27pm
Glideman
Location: Stood next to a broken down Range Rover in Darwen
United Kingdom 2003 Range Rover Vogue 4.4 V8 Zambezi Silver
Mine is more of a heavy suspension knock to
Post #97998 16th Dec 2011 2:28pm
PeterY
United Kingdom 2010 Range Rover Vogue TDV8 Santorini Black
Did anyone ever find a reason for this, sounds very similar to mine.
I've replaced upper and lower arms and ball joints, only thing I have noticed is slight movement on both inner cv joints when holding the shaft they move in any direction about 5mm. Equal movement on both sides so not sure that they are a problem.
Mine started after being on my 2 post for a day while I changed the alternator and did a few other jobs, I can only assume that the weight resting on suspension has put something under extra stress. 2009(10MY) 3.6 TDV8 Vogue
2004 BMW M3 CSL
Post #363478 22nd Dec 2015 2:12pm
rads
Jeez,
It's only been 4 years.
Give us a chance!
Still knocking.
Happy Christmas, Glideman!
David
Post #363505 22nd Dec 2015 5:07pm
Glideman
Happy Christmas David, mine is still doing the same. Never been able to cure it, mind you the gearbox leaking is taking my mind off it at the moment.
Since I was last on
the air con has failed
Rear windscreen wiper failed
Gearbox leaks and slipping
Rust started appearing at sill
Rear suspension bushes worn out again
Rear bottom tailgate won't close
Led display stopped working
Been looking at a new Kia, they do a 7 year warranty and have a good dealer network apparently......... Range Rover 4.4 V8 Vogue
Post #363512 22nd Dec 2015 5:47pm
rads
Genuinely sorry to hear that.
May not help to tell you mine has been absolutely bullet proof.
EXCEPT FOR THE DAMNED KNOCK.
Perhaps I should buy yours?
Can't beat a good pair of knockers...
David
Post #363565 22nd Dec 2015 11:31pm
