Home > Maintenance & Mods (L322) > touchscreen display dim on startup
a few times now over the last 2 years , my display hasnt got to its full brightness on startup , especially if i havnt used the FF for 3/4 days..
i did find that after stopping and then re-starting again the display would go to its normal brightness..now this is ok if you do a short journey but on a long run it can be annoying and frustrating..
the solution is to use voice control to command 'display off' and then 'display on' and the display will come to its full brightness without you having to stop and re-start.. ... - .- -.
Post #363240 21st Dec 2015 11:42am
Have you tried a software update from the iid Stan?
Post #363248 21st Dec 2015 12:15pm
? more info please craig-meister... ... - .- -.
Post #363250 21st Dec 2015 12:19pm
You can do an update which allows “nav on the move” etc etc Stan, i know yours is new enough to have that feature! But if you do an update to latest software (if indeed it will allow you to) then it will over write your software and if your issue is software related... Voila!!!
Post #363252 21st Dec 2015 12:22pm
i have 'nav on the move' already Thumbs Up
but i dont think the dim screen is a software problem more that the lcd screen doesnt get its full power when starting... this is something that has only happened to me a few times over more than two years so its not a great problem... ... - .- -.
Post #363253 21st Dec 2015 12:34pm
chefkenmore
Scotland 2014 Range Rover Vogue SE SDV8 Loire Blue
Mine does that! Sometimes!
2007, so what do I do Stan?
Busy stuffing turkeys................................... 2014 vogue se
Post #363402 21st Dec 2015 11:44pm
RR2008HSE
Mine too. But not often. I'll watch this with interest. I have the iid, so any instructions are most welcome. Cheers. Bow down
Post #363412 22nd Dec 2015 12:28am
Me as well , I used to think it was the cold but clearly not the case here . Both cars have done it and it's very random so I just ignore it . Every year or so there is a post about it so it's not that uncommon but no one has ever got to the bottom of this . 2008 MY Supercharged
Post #363417 22nd Dec 2015 2:10am
55palfers
United Kingdom 2008 Range Rover Autobiography 4.2 SC V8 Santorini Black
Same problem on mine from time to time Stan.
Eventually it gets to correct brightness.
Post #363435 22nd Dec 2015 9:59am
i dont think its a big concern Mike as [you say] it will correct itself , but by switching the display off using voice command ,the display comes back straight away to full brightness..
for those who want to do a software update then craig will probably explain where/how/who/when/what to do... Very Happy ... - .- -.
Post #363437 22nd Dec 2015 10:18am
JPS
2005 Range Rover Autobiography Td6 Zambezi Silver
It could be to do with the auto light sensor that dims the screen, this time of year on these dull dark days especially if you have tinted windows the inside of the car can be pretty dark so naturally the screen will dim as it thinks its night time
Post #363438 22nd Dec 2015 10:23am
it could be but my screen is brighter than that at night than when i get the dim screen...
i reckon its a power thing where its to cold and it doesnt get the kick it needs to start properly..i've left electronics in the FF for a few days during winter and the lcd screens on these tend to go dim or not work at all.. ... - .- -.
Post #363441 22nd Dec 2015 10:30am
robbo770
Scotland 2005 Range Rover Supercharged 4.2 SC V8 Zambezi Silver
I have come across a worn out dimmer adjuster on the main headlight switch module cause this
Solution fit a new module and the variable resistance issue is fixed Current vehicles
4.2 SC FFRR RSE 2010- facelift
Range Rover Evogue Dynamic Lux
Gone
Rejected RRS my14.5 nightmare
Disco B4 XXV convert
Freelander 06 SE
06 RFFRR 4.2 SC Vogue RSE
Audi A8 4.2Tdi Quattro (hated with a vengence!!)
54 FFRR 2005 model V8 4.4 Cobra Variant
53 Mitsubishi Shogun V6
Post #363444 22nd Dec 2015 10:47am
it wont be that as that dial controls the speedo/rev lighting and thats not affected when the screen goes dim...as it happens the lowest setting on the dial is still brighter than the screen when it has its hic-cup.. ... - .- -.
Post #363451 22nd Dec 2015 12:12pm
DallasRob
United States 2008 Range Rover HSE 4.4 V8 Tonga Green
Have searched the forum for posts related to this, but no luck (yet) finding a definitive answer/solution. My 2008 HSE has developed this exact problem. It has a brand-new screen from the dealer (thank you, extended warranty) AND a software fix related to the system staying stuck on the Land Rover oval while it turns itself off and on every two seconds. That problem seems to have disappeared after the software fix — but this morning, dim again on startup. The truck is parked in a subterranean garage every night and it was 50 degrees Fahrenheit in Dallas this morning. Any further info on this problem?
Post #466016 25th Jan 2018 7:17pm
