Home > Maintenance & Mods (L322) > Filling up! |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35380 |
sounds like the fuel guard has been activated...there should be a plastic yellow thing in the boot that can reset it...should be info in the owners manual re this.. ... - .- -.
20th Dec 2015 10:11pm |
Terrier Member Since: 17 Dec 2015 Location: Yorkshire Posts: 51 |
Thanks Stan |
20th Dec 2015 10:13pm |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16298 |
Look down the filler nozzle and see if the fuel guard has been activated... It does not need to be fully activated to inhibit the flow when your refilling! And can be activated by a large pot hole
21st Dec 2015 1:01am |
Dtech Member Since: 29 Nov 2014 Location: Yorkshire Dales Posts: 55 |
Turn the pump nozel upside down. Always works for me |
21st Dec 2015 2:09am |
mpirie Member Since: 26 Jun 2012 Location: In the Highlands Posts: 900 |
^ +1 |
21st Dec 2015 7:26am |
Pvw10 Member Since: 04 Nov 2015 Location: Ledbury Posts: 315 |
+2 Many thanks
21st Dec 2015 4:43pm |
And if you all put the reset tool in................... Yep you guessed it! You could fill up NORMALLY |
21st Dec 2015 4:48pm |
21st Dec 2015 4:49pm |
Not true for me sadly, mine was set correctly Many thanks
21st Dec 2015 4:50pm |
^ +1 |
21st Dec 2015 11:06pm |
RJH Member Since: 22 Mar 2015 Location: Coventy Posts: 398 |
Make sure the tank isn't actually full already!!
21st Dec 2015 11:44pm |
Good shout but I put £50 in at a time generally and the clicking from the pump is immediate.
22nd Dec 2015 4:30pm |
Mr Tee Member Since: 13 Dec 2010 Location: Near Wackyjim Posts: 2656 |
Both my td6 & tdv8 are the same , always Sainsbury for fill up , but had the same at different forecourts. Just think it's a very poor design, just wait until the reset tool snaps in the filler neck , that was a happy day! I keep a long screw driver in the boot for that purpose now! |
22nd Dec 2015 5:40pm |
It would be interesting to know just how many people suffer in silence with this fuel filling problem. This is my third RR in the last 10 years and all have had the same problem. Never have this problem with the defender |
23rd Dec 2015 2:41am |
