Home > Maintenance & Mods (L322) > power steering fluid
i've just replaced my servotronic valve and need to top up the power steering fluid , so has anyone used anything other than the user manual recommended stc50519 fluid ...if so, any problems... ... - .- -.
Post #36320 16th Nov 2010 12:14pm
I can't help with your question scarey, but can I ask why you changed the valve and what was involved?
Post #36321 16th Nov 2010 12:34pm
my steering was getting heavy on slowing for corners and roundabouts cos the valve could not cope with the sudden speed change and after searching the web and talking to a LR mechanic it was diagnosed to be the valve..this valve regulates how light/heavy the steering is at what speed the RR is travelling at...
very easy to change, take the off side wheel off and its there in front of you , undo two bolts and replace..cost of valve ,about £60 inc... ... - .- -.
Post #36322 16th Nov 2010 1:43pm
mzplcg
Not specific to PS fluid fella, but a past experience taught me to only ever use the correct specification of lubricant. Sure it costs a bit more but I look at it in terms of the uplift in cost.
Take proper spec Castrol for the Wife's XF. Only available from Jag and 12 quid a litre. BUT. Compare the cost of another premium oil as being about half that. With the required 6 litres it comes in at about 30-40 quid in uplift which, compared to the potential issues with using a lesser spec is about the square root of sod all.
Some say that Oil is Oil. I usually answer by telling them to fill their autobox with GTX 20/50 and see what happens.
Sometimes, saving 40 quid is a truly false economy. Lubricants, brakes, tyres etc all fall into that "Sometimes" for me.
Dom
Post #36323 16th Nov 2010 2:19pm
Thanks for the info scarey.
I have to agree with what mzplcg has written and stick with OE oils
Post #36324 16th Nov 2010 2:28pm
thanks for the input chaps, its only a very small top up i need and i'm a bit reluctant to spend £17/18 for a big bottle of the stuff...but it does make sense..... ... - .- -.
Post #36325 16th Nov 2010 2:36pm
RRBlue
England 2005 Range Rover Vogue SE 4.2 SC V8 Buckingham Blue
I have a 2005 s/c and can not find any record of power steering fluid changes over some 145k miles. Whilst the steering seems generally fine, I have noticed some heaviness and the odd change in feel. I tested the fluid which was dark brown and smelt like burnt toast.
Therefore, I invested in 3 litres of the manufacturer recommended green fluid at £18 per litre and have changed it today. The steering is noticeably lighter!
The dealer told me that when they do a flush they use 6 litres and the charges would be in excess of £200. Whilst my change may not have achieved the cleanliness of the flush, I have improved performance noticeably for £50 and I m surprised that this does not form part of routine maintenance to at least improve the life of the ump and hydraulic gear. I shall repeat at 200k if we make it that far!
Post #162116 5th Jan 2013 10:34pm
arron
United Kingdom 2005 Range Rover Vogue Td6 Java Black
i done quite a bit of research on this as i wanted to flush my power steering fluid, after a lot of reading it turns out that texaco 7045e as used in the transmission is also recommended for the steering or at least thats what it says on the texaco web site.
Post #162131 5th Jan 2013 11:19pm
@ arron
That's good news, I have a barrel of the stuff sat sitting in the garage Smile .
Post #162132 5th Jan 2013 11:31pm
the things you get for xmas 'eh Tim.... Laughing ... - .- -.
Post #162362 7th Jan 2013 9:02am
