Home > Technical (L322) > Headlight no work |
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6730 |
Fuse maybe? Got - 2017 SDV8 Autobiography in Loire Blue
20th Dec 2015 1:34am |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16294 |
Fuses? |
20th Dec 2015 1:36am |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3977 |
No fuses for the headlights, they are protected by mosfets in the LCM.
20th Dec 2015 7:54am |
The OP has an Aussie HSE so will most likely be “halogen” headlamp bulbs ndfi... |
20th Dec 2015 11:29am |
So he has. No ballasts as a problem then but the filaments are still protected by Mosfets. Not sure why both filaments should be off in one headlight though. Possibly worth checking the earth to the headlight. Maybe even do a battery disconnect/reconnect and see what happens.
20th Dec 2015 11:37am |
3528cc Member Since: 29 Oct 2014 Location: North East Posts: 301 |
Plug on the lamp unit? Regards
20th Dec 2015 4:16pm |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8557 |
Would say it's likley to be something specific to that light. There won't be a fuse or mosfet specifically for one side?
20th Dec 2015 5:21pm |
littlecub Member Since: 02 Apr 2013 Location: Ulverstone,Tassie Posts: 325 |
Was some early bits of corrosion.
21st Dec 2015 3:53am |
