![]() | Home > General (L405) > Where Do I Go From Here - LR Not Helping |
Basilfawlty Member Since: 18 Oct 2015 Location: Cheshire Posts: 655 ![]() ![]() ![]() |
Hi Carl, sounds awful. Do I take it from what you've written that you've had it for eight months? and you've had this trouble right from the start? If so it seems from what you've said and what your dealers technician have confirmed that your car may not have been of satisfactory quality (Sales of Goods Act).
carlos50 Member Since: 03 Feb 2011 Location: North England Posts: 717 ![]() ![]() ![]() |
Hi, yes, bought it as an approved used vehicle in April this year and it's always drove like that. I threatened that to the guy at LR when he called to say he was closing my case and he didn't seem to care. It's a route I'm thinking about but wasn't sure if it would apply to a used purchase? It's my thought that since dealers are replacing parts in an attempt to improve it then my complaint is valid so I think I'll write to them anyway.
Yes I think I would do it sooner rather than later. I have read a thread on the L405 forum previously regarding a similar issue so you might want to check. |
Print out the Consumer Rights Act and read it thoroughly. Your right to reject is initially limited to 30 days now but there are other parts of the act (around repairs) which state the retailer must carry out those repairs within a reasonable time.
Philip Member Since: 05 Jan 2010 Location: UK Posts: 2616 ![]() ![]() |
Suspect you're not kicking up enough fuss in the right places at Land Rover - a dealer's senior mechanic on record as saying it isn't right should be reasonable evidence of a problem. |
I've just emailed a contact at Trading Standards to ask her exactly where I stand, lets see what she says.
Carlos,
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1401 ![]() ![]() ![]() |
You are probably at the stage where you need to get proper legal advice from a solicitor who knows consumer protection law.
robbo770 Member Since: 10 Jan 2010 Location: Aberdeenshire Posts: 467 ![]() ![]() ![]() |
If you have a finance loan on the car, just get them involved and supply all evidence, they will complete in 56 days and as you have factual evidence the faults are from when you got the car, a refund will be sorted out.
Wow, thank you for the advice, seems very daunting, slow, painful and costly if it didn't go my way, the joys of RR ownership |
Very straight forward if your still paying for the car, the company should have a specialist department just on things like this, takes the pressure off as your entitled to get your money back |
Ok thanks for that, I am still paying for it so will take that route after letting the dealer have another crack at it. |
RR P38 Member Since: 12 Oct 2013 Location: Sydney Posts: 215 ![]() ![]() ![]() |
Standard wheels and tires?
Factory 21" with Pirelli factory tyres, all 6mm plus. The dealer Im currently using supposedly went over every aspect of possible causes and found nothing, dampers all changed for latest spec recently so my guess is it still needs the ARC valve block fix and possibly the steering rack?
