![]() | Home > In Car Electronics (L322) > AV Off Message |
thegamekeeper Member Since: 12 Nov 2015 Location: sunderland Posts: 71 ![]() ![]() |
i have this message too. its just came on but the radio is ok. did you find out what it meant. thank you |
Zirconblue Member Since: 16 Apr 2015 Location: Kent Posts: 1277 ![]() ![]() ![]() |
you've got a fault with your radio/CD, or maybe just the on/off button. So your radio is switching on and off and putting the message on the screen. I would bet if you set your message centre to display say MPG rather than Radio station or CD track your radio will still be going on and off but you wont get the message. |
Deanr_777 Member Since: 22 Sep 2013 Location: England Posts: 12 ![]() ![]() |
It was a fault in the Nokia box in the back. It has 2 fibres gong into it. One sends data and one receives data. All to make a loop. If the Nokia box fails it won't send out the data it recieves. This trows out the error. The solution is to take out the fibres from the box and plug the fibres into an optical loop back. You need to make sure that the loopback is the right mode sinle mode or multi mode. I can't remeber which mode is on the vehicle. You alo need to make sure the connectors on the Ennis of the fibre. Again I can't remeber what they are. Black box steel these optical loopback. Once you have done this the Nokia box, which is the hands free unit will not work of course.
forever Member Since: 06 Oct 2015 Location: Oxted Posts: 319 ![]() ![]() |
Would replacing the nokia box not be the better solution, after all hands free is pretty much a legal requirement... |
Of course but. That was a quick and cheap fix. Again if I remember correctly, the lead time was quite long for the box and they weren't too available. I don think they are cheap either.
Only if you want to answer the phone, sometimes its better that people can't get hold of you. ![]() |
