Home > Technical (L322) > Air Suspension - Gallery Pressure
DMRR
South Africa 2009 Range Rover Westminster TDV8 Stornoway Grey
Hi All,
I'm trying to work out if I have a faulty pressure sensor or tired compressor. Could someone with an IID or anything else that can read the gallery pressure give me a reading - I need something to baseline on as the fault is intermittent Sad Land Rover Addict
XXXXXXXXXXXXXXXXXXXXXXX
Previous
XXXXXXXXXXXXXXXX
2009 5.0V8SC Autobiography
2006 4.2V8SC Autobiography
2004 4.4V8 Vogue
Post #362715 18th Dec 2015 9:07am
dingg1
What are the symptoms ?
Post #362742 18th Dec 2015 11:56am
DMRR
Intermittently I get the code for C1A20 Pressure increases too slowly.
I know it's either the compressor or the sensor. I've reflashed the ECU for the compressor and it's made to difference. However I get random values from the live view - sometime 1500 (error will occur) and sometimes 300 (no error and all is well for days and days)..... I really need to know what the sensor should be reading when sat at normal ride height with the compressor not running, if that makes sense. Land Rover Addict
Previous
XXXXXXXXXXXXXXXX
2004 4.4V8 Vogue
Post #362743 18th Dec 2015 11:59am
dingg1
ok , just thought it may have been getting the pressure trapped due to choked exhaust silencer , sorry can't help with your issue
Post #362744 18th Dec 2015 12:02pm
markcartlidge
My IID reads about 172 to 186 bar for an 02 reg.
Post #362746 18th Dec 2015 12:23pm
dingg1
186 BAR Shocked
are you sure???
Post #362754 18th Dec 2015 1:23pm
markcartlidge
I suppose it could be psi, I didnt take much notice and with the pixels missing it wasnt obvious.
Post #362757 18th Dec 2015 1:34pm
It's PSI but the earlier ones are different to yours...
From Rave for yours
Pressures:
Normal - Front
800 to 1000 kPa (8.0 to 10.0 bar) (116.0 to 145.0 lbf/inē)
Normal - Rear
500 to 800 kPa (5.0 to 8.0 bar) (72.5 to 116.0 lbf/inē)
Air supply unit:
Comprises a piston compressor, 12 volt electric motor, solenoid operated exhaust pilot valve, pressure relief valve, air dryer unit and two silencers
Controlled by
Air suspension control module
Working pressure
1450 kPa (14.5 bar) (210.3 lbf/inē)
Maximum pressure
2700 kPa (27 bar) (391.6 lbf/inē)
Air reservoir:
Volume
10.2 liters (622 cu.in)
Nominal working pressure
1440-1550 kPa (14.4-15.5 bar) (208.85-224.8 lbf/inē)
Maximum operating pressure
2200 kPa
Good luck... Thumbs Up Pete
Post #362780 18th Dec 2015 3:44pm
DMRR
Cheers - time to order a refurb kit then! Land Rover Addict
Previous
XXXXXXXXXXXXXXXX
2004 4.4V8 Vogue
Post #362782 18th Dec 2015 3:55pm
