Home > Maintenance & Mods (L322) > Larger Battery upgrade on L322 TDV8
mario.costasa
United Kingdom 2008 Range Rover Vogue SE TDV8 Java Black
Not sure I have seen a write up on this but here are some photos (click the gallery button below) of the simple mods I had to do to fit the large battery in my 2008 RR TDV8.
I went for the Varta I1 / 610 402 092 which cost me only �95 delivered (within 48hrs)
12v 110Ah 920CCA
Length (mm) - 393
Width (mm) - 175
Total Height (mm) - 190
Weight (Kg) - 25.2
Terminal Type - Standard Post (A)
Terminal Layout - RH+
Warranty5 YEARS
Battery Megastore UK Limited (sales@performancebatteries.co.uk)
http://www.ebay.co.uk/itm/Varta-Silver-I1-...616426577?
The larger case size is (just) fine, this issue comes with the black box which I was warned was an explosive disconnect but turned out to be a big & boring fusible link.
This needs repositioning from the side to the top.
I have attached photos of the critical bits - if enough interest I will do a full write up - but it is simple enough job and I have noted a few "quirks" seem to have gone away with eth bigger battery.
For �95 I am very happy
Mario
07721 480000
 Mario
Post #362351 15th Dec 2015 4:48pm
rangie_mike
United Kingdom 2011 Range Rover Autobiography 5.0 SC V8 Orkney Grey
Nice write up and pics.
I'm thinking of upgrading my battery. My audio/video soon shuts down without the engine running. Current : Range Rover 5.0 SC 2011 Orkney Grey
Previous : P38 4.6 Vogue 2000, Audi A4 Avant 2.5Tdi Quattro Sport, RR Classic 3.9 Vogue, BMW M535i, BMW 525e, BMW 2002tii, Austin Metro
Post #362363 15th Dec 2015 6:03pm
Rangeyman
Does the diesel not have the larger battery anyway ? I already had the large battery on my 4.4 petrol !
Post #362389 15th Dec 2015 10:51pm
