![]() | Home > Technical (L322) > 2009 5.0 SC GEARBOX FAULT WARNING |
Zigzagsky Member Since: 18 Oct 2015 Location: Sandhurst Posts: 39 ![]() ![]() ![]() |
Best thing to do would be to get a diagnostic tool connected and the fault codes read. Sounds like the gearbox went into 'limp home' mode which means it detected a problem and went into a safe mode.
andrew-a Member Since: 07 Sep 2011 Location: Wirral Posts: 70 ![]() ![]() |
Thanks Zigzag. So a fault code will have been logged even though there is no fault warning on the dash at present? Is this an indication of a future problem with the gearbox or just a one off event? |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35490 ![]() ![]() |
it could be something like a height or abs sensor come loose.....as said above , get the codes read... ... - .- -.
Yes the fault code will remain logged in the system until cleared. It could be a one off (electrical connection) but once cleared see if it occurs again which may point to an upcoming issue. 2005 Range Rover L322 TD6 2009 Jaguar XK 5.0 Portfolio 1969 Jaguar E Type Series 2, 2 Plus 2 |
