![]() | Home > Maintenance & Mods (L322) > Gearbox software upgrade |
Lost for Words Member Since: 18 Jun 2015 Location: Warminster, Wiltshire Posts: 473 ![]() ![]() |
I'm sure Pat would/will warn you, since it's part of the "Fast Lane" service, but care must be taken when flashing the gearbox - the adaptive values must be reset and the TCM musn't be over 80 deg C IIRC. If the box is on it's last legs, it can end very badly. Not trying to put anyone off; just be aware. |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8529 ![]() ![]() ![]() |
PLEASE PLEASE PLEASE chaps as LFW says.... don't update anything unless you are having problems with it and then be prepared for it to be an all or nothing issue....
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35633 ![]() ![]() |
here's an extract from a pm from Pat,
If the box is knackered though, an adaptive reset can also push it over the edge. |
PatGAPInnov Site Sponsor Member Since: 01 Dec 2011 Location: Montreal Posts: 153 ![]() ![]() ![]() |
Some firmware do provide improvements and do help in prolonging the life of a component. For example, the suspension ECU reflash on older cars which increases the compressor motor life expectancy. In this case, there is no particular risk associated with updating the ECU.
blackstoun Member Since: 22 May 2015 Location: Scotland Posts: 116 ![]() ![]() ![]() |
Mine is a 55plate (probably 06 MY)
holidaychicken Member Since: 06 Nov 2013 Location: Kent Posts: 1086 ![]() ![]() ![]() |
I thought that may be the case, i found a trouble shooting flowchart from ZF that referred to the harsh clunk and the software upgrade but i dont think they did such a thing for the ZF5HP24.
