Home > Technical (L322) > Forward Alert not available - dashboard msg |
Lost for Words Member Since: 18 Jun 2015 Location: Warminster, Wiltshire Posts: 473 |
Good point actually; I'm not sure (oh dear me...what was wrong with the simple key?! ). I guess that may mean the ECUs are wired such that it will work without (?), but otherwise, I don't know. I'd try it without anyway. Visiting from DISCO3.CO.UK
1st Dec 2015 2:36pm |
Or leave the live connected to the battery , disconnect the earth lead, then connect a wire from the live lead to the disconnected earth terminal lead and that will drain the residual power |
1st Dec 2015 2:44pm |
comports Member Since: 20 Dec 2010 Location: Colchester Posts: 1702 |
I don't, sorry but when mine goes into a fault with the forward alert the adaptive cruise no longer works (they do use the same radar)
9th Dec 2015 6:07pm |
Fleagle_UK Member Since: 20 Mar 2013 Location: Cheshire Posts: 409 |
no worries folks - guess I'll book it in at the local dealers to see what they say it is.
10th Dec 2015 11:55am |
Well - with still about 2 weeks to go before the dealer will look at the problem.....but....
10th Jan 2016 10:22pm |
Stormin Member Since: 22 Feb 2012 Location: West Yorkshire Posts: 266 |
Fleagle_UK
30th Jul 2019 5:16pm |
Afraid not. It behaved itself after that. All I could guess was just a software glitch. |
30th Jul 2019 7:36pm |
ifelton Member Since: 18 Jan 2021 Location: Merseyside Posts: 1 |
Hi guys, did anyone else find what is causing this as mine is doing it now. |
18th Jan 2021 8:20am |
On mine one of the height sensors is going bad (new one on order). When it loses the signal (and you can see it "drop away" on the 4x4 info screen) the suspension alert comes in. That then knocks off the forward alert and cruise control as well.
18th Jan 2021 8:43am |
