Home > Technical (L322) > brake lights and hdc fault |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8147 |
Sounds to me like your Hawkeye is playing up... With that array of lights you would think it would have more faults logged.... Pete
8th Dec 2015 1:30pm |
Weejock Member Since: 30 Dec 2011 Location: UK Posts: 417 |
Sounds like you have a short to positive that's turning on the brake lights, so what the Hawkeye is reporting is correct.
9th Dec 2015 2:37pm |
dogswick Member Since: 14 Jan 2012 Location: ever sunny yorkshire Posts: 20 |
haylands, thought that at first or maybe the red adapter but everything else i.e. service functions and other test work fine so pretty sure the hawkeye is fine.
10th Dec 2015 9:30am |
They do come on with HDC, mine came on on their own with the ignition off after I drowned the car in a river... could be water in your electrics somewhere, check the carpets for dampness... Pete
10th Dec 2015 10:18am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35217 |
re brake light on, check the body control ECU in the passenger footwell, it might have got wet from blocked sunroof drain pipes..
10th Dec 2015 10:25am |
I like a challenge and this could be a complex one!
12th Dec 2015 9:37am |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6407 |
^^^ Stunning .
12th Dec 2015 11:36am |
Weejock you are a deity.
14th Dec 2015 3:59pm |
No problem, glad you got it sorted!
15th Dec 2015 12:35am |
SMUTT Member Since: 30 Jun 2014 Location: Cheshire Posts: 459 |
@Weejock - great bit of detective work there Howard
15th Dec 2015 10:56am |
DDJJKK Member Since: 24 Nov 2014 Location: Perth Posts: 1 |
Great posts helped me diagnose the exact same problem with my l322 td6 abs ECU faulty
9th Apr 2017 11:49am |
