Home > In Car Electronics (L322) > Rear dash camera fitment |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7969 |
You have 2 choices, either fool the car into thinking it's reversing by tapping into the wiring - which is what I assume the switch that Welshdragon installed is for - or you can disable the safety feature that prevents you watching TV whilst on the move.
8th Dec 2015 11:19am |
Chasazim Member Since: 21 Jan 2015 Location: Perth Posts: 128 |
Thanks for the tip, will do more digging, |
8th Dec 2015 12:04pm |
Welshdragon Member Since: 20 Jan 2012 Location: here and there...but not where I should be Posts: 1899 |
The switch I fitted is the 'fooling' way of wiring it up, I did not want the reversing light to switch it on as wanted forward viewing for the trailer, which works brillianty.
9th Dec 2015 6:06pm |
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6740 |
I had/have a little box that I used on my E60 when I had it. I wired it to the reversing light but also to the can-bus so that I could press the knob in the centre console and it would come on without selecting reverse.
9th Dec 2015 8:17pm |
Hello WD yes all the same, I ordered from the links you posted, I get a good picture on the head unit if it is set to Pal and the connection from the cam is in the video in jack with the earth from pin 17 not connected, when I wire it up as per instructions it messes the computer around and it does all silly things, like activating the GPS on its own. Can you tell me a bit more about that switch on the centre consol if that shuts off the nanny message then she will be right I still cannot access the Menu but I can live with that. The cam is recording fine.
10th Dec 2015 3:09am |
My switch is just a normal rocker type with 2 pins, simple on off which goes through to pin 17 on blue connector. The switch would of been the reversing light to activate camera, don't know why your gps is going on?! A bit confused about that sorry.
10th Dec 2015 9:11am |
Good morning to you, sorry if I am a bit vague This electrickery is not my game at all but I try,setting in the head unit is no problem if I have the cam plugged into the video-in plug on the new harness, but if I plug the cam into the camera-in plug and connect socket 17 to earth then I have no access to anything on the head unit, just a rolling picture, no access to any features. The radio, cd and tape work but in the background. I noticed that when I connect pin 17 to earth the navigation unit switches on and all the courtesy lights come on so it seems the system is powering up even though I haven't done anything else but connect 17 to earth.
10th Dec 2015 9:57am |
Hmm got me on this one, I have no idea why the courtesy lights come on and you naviation too, mine dont, also to answer your first question (I've reread my hole thread again) yes the music does play in the back ground.
10th Dec 2015 7:11pm |
Its been a while but I do look in now and then to see whats new here!
31st Dec 2017 7:18pm |
