Home > Technical (L322) > gear changing
thegamekeeper
2006 Range Rover Vogue Td6 Java Black
gear changing
hi
ive been told its possible to have the gear change reprogrammed to change soonr as mine seems to change a little late. about 2000/2500 rpm and it sounds too high. is this correct
thanks
tony
Post #361455 10th Dec 2015 9:59am
If it's doing it all the time then it sounds like a faulty ECU to me, they have a cold start mode that holds the gears to warm the engine up quicker but this should stop when the engine is up to temp... so if it does it all the time there is a fault with the gearbox ECU OR the engine isn't getting to temp, stuck thermostat would be the first place to look...
Take it for a good long run and see if it still does it.... Pete
Post #361474 10th Dec 2015 11:22am
a remap should be able to adjust the level at which the gears change ... ... - .- -.
Post #361476 10th Dec 2015 11:27am
thegamekeeper
hi again
its not all the time it does change a lot when it warms up but it still feel high around the 2000 rpm mark. the kid i spoke to said theres a way to reset the box using the accelerator etc but your the lads to say if this is so or wise to do so
Post #361487 10th Dec 2015 11:53am
