![]() | Home > Maintenance & Mods (L322) > My exhaust is exhausted |
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2035 ![]() ![]() ![]() |
you could go to an exhaust specialist, and ge it repaired. i mean, it might be just the downpipe to manifold joint leaking, or maybe even the manifold itself is cracked. you should at least know that its not repairable before getting a sports exhaust at great expense. better people can weld a stainless or mild stell exhaust -even if it means taking it off -and the 4.4 exhaust is held on with just those 4 bolts to the manifolds, and some rubber hooks! its a whole one piece assembly. -till you cut it to service/repair parts of it.
I had a similar hole in the front crease/seam of the Cat where the Catalyst front end goes into the up exhaust pipe and into the engine (Hope that makes sense |
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1416 ![]() ![]() |
Had similar with mine. Fixed day.... See this thread....
Nice pics Fisha.
rathbranV8 Member Since: 23 Jan 2011 Location: meath Posts: 283 ![]() ![]() ![]() |
Recently had mine repaired as well.Lambda settings on the high side as air getting in and same put put sound when cold.There was a recall for this in the US as the seam welds on the cat go.Mine went on the drivers side along top edge.Exhaust shop welded it for me and took the liberty to remove the centre resonator and weld in a balance pipe.Nice sound now |
mat777 Member Since: 06 Apr 2015 Location: Nantwich/Liverpool Posts: 139 ![]() ![]() ![]() |
Thanks chaps. I've not had any EML lights yet but I will have the system checked and welded whereever it is cracked - so I can keep saving for a nice custom system all in one go |
The car is booked in for an MOT early in January, the garage have said they will have a look and if they find a crack, will have a go at doing it for me. The noise is definitely getting more noticeable, but it only does it when cold so it obviously seals back up again when the exhaust is hot. NW060
Ivor Member Since: 26 Jun 2015 Location: Aberdeen Posts: 223 ![]() ![]() ![]() |
If it seals when hot I would say it's a gasket not a crack L322 2008 vogue
Hmm I see. That must immediately point to the downpipe to rest of system joints then, seeing as it's one piece from there on? NW060
your best bet if you are confident on the car is to start it raise to max height and have look listen underneath you will soon locate where it's coming from ,if it's a crack you would hear it all the time and possibly get louder when warm L322 2008 vogue
A bit of an update - during the mot at my local garage they had a look at it for meand diagnosed a badly cracked cat. They offered me the choice of a new cat at 270 quid plus fitting, or welding the existing one in situ for 50 quid all in. Hmm, tough choice!
you did the right thing. if you had bought a £270 new cat, it would have died a few years later, and it would have needed to be welded, or bodged on. the original cats are huge money, (and are a complete exhaust.) i had newish cats (2 years) on mine when i bought it, and one was rattling, and i was getting codes... i bought a pair of original cats from a low milage, and fitted, albeit with clamps, and a sleeve, but its perfect now. for reference, i paid £250 for the pair, and they had done just 29k. ( with proof) it was a bargain to me. but you can buy whole exhausts for that secondhand, but they are too hard to transport etc. |
