![]() | Home > Maintenance & Mods (L322) > Rear brake pipes |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8553 ![]() ![]() ![]() |
Yep, standard size brake pipe 4.8mm.... standard joiner, just make sure you use the correct single or double flare for the joiner... The steel original pipes are a pain to flare when still on the car, if you can, unclip a good couple of feet and have it hanging down so you have good access to the end.... Pete
RRBlue Member Since: 24 Feb 2012 Location: Cambs Posts: 222 ![]() ![]() ![]() |
Thank you. Very useful. Clearly I should flare the pipe on the bench before I fit it. 2014 5.0 Supercharged Autobiography & 2015 3.0SDV6 HSE Lux Discovery 4
Rangeyman Member Since: 03 Feb 2015 Location: west yorkshire Posts: 267 ![]() ![]() ![]() |
That is why I bought the copper type,put the flaring on first then just bent to shape and easy to thread through ! |
You can't flare the end of the one you cut on the car, on the bench... hence the tip..... Pete
I would have bought copper if I had thought this through properly.
SteveyD Member Since: 11 Dec 2012 Location: Cheshire Posts: 352 ![]() ![]() ![]() |
HI. You don't need to drop the sub frame at all, my rear lines failed last week and I replaced all of the hard lines on the car. I bought oem lines, they cost about £18 each. The drivers side rear was tricky but can be carefully manipulated into position without bending past the point of failure. I was fortunate to have a twin post car ramp but the job could have been done without. The job took me just under half a day for all of the lines.
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2035 ![]() ![]() ![]() |
if you are buying brake pipe, look for the 'kunifer' type. its nickle plated copper. so it wont go green. it looks silver for ages too. and it easier to bend. best to bend it to rough shape first. put some tape over the end, so it stays cean till its flared or screwed.
Zirconblue Member Since: 16 Apr 2015 Location: Kent Posts: 1277 ![]() ![]() ![]() |
i think it's actually a Copper/Nickel/iron (CuNiFer) alloy, rather than plated. The nickel and iron are there to make it more flexible and stop it from going brittle. |
i stand corrected, go to the top of the class, Top-boy, and leave your apple on his desk as you pass.
To be honest until i googled it to double check i was right, i'd been spelling it with a K like you, i hadn't realised the name was the actual chemical formula.
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6419 ![]() ![]() |
Sure the OP has already found this, but just in case
noworries4x4 Member Since: 03 Oct 2013 Location: Newton Abbot Posts: 166 ![]() ![]() ![]() |
I went for the very lazy option and used Goodridge braded hoses with the protective fire coating on them. If everything is under control you are not going fast enough.
