Home > For Sale & Wanted > [Wanted] N/S/R 2010 Led Rear Light
Josh Wyatt
United Kingdom 2014 Range Rover Vogue SE SDV8 Causeway Grey
I'll have prices tomorrow afternoon for rear light lenses and front light lenses for the 2006-2009 headlights, and 2010+.
He has suggested the following for the rear light lenses, and will create a few samples of each;
Original thickness plastic for direct replacement.
Extra thick / strength - He is however unsure how it'd look fitted to a lamp, so this needs to be tried as this plastic is thick and pretty strong. Wants to make sure it doesn't effect the light output.
Original thickness or even slightly less but with a more plyable plastic material. It'd look the same, but would flex somewhat, so hopefully may prevent cracks or off road damage etc. All sounds good, but until tested he's not sure.
Post #355156 3rd Nov 2015 6:26pm
Well I'll have a passenger side front 06-09 lense please and a drivers rear for the same age as I have a broken unit to test it on 👍 FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #355174 3rd Nov 2015 6:53pm
i think the front ones need to be perfect because of the beam projection and maybe be 'E' marked ? ... - .- -.
Post #355175 3rd Nov 2015 6:58pm
Josh Wyatt
Sorry for the delay in getting back to everyone. I have my final meeting with him tomorrow, he's got samples for me. I've got a rough idea on prices, each rear lens is between £11-£26 depending on material thickness as discussed earlier.
Stan does very correctly point out the legal requirements for headlight casings, he's still unsure what to do regards this. He doesn't want to sell something you can't use, but can produce headlight lenses for around £38 each.
Post #356334 11th Nov 2015 10:32pm
Scangerry
Jordan 2005 Range Rover Vogue 4.4 V8 Zermatt Silver
Hi New to the FFRR hello ! I am looking for a left rear lamp/lens for my 05 FFRR- here in Jordan are hard to come by and get broken regularly by the friendly bumps the traffic here is prone to - can pick up in London UK if anyone can help , the lens would be perfect if he has made them -please advise how we can buy. Many thanks
Post #359916 1st Dec 2015 12:01pm
