Home > In Car Electronics (L322) > RSE Remote control 2010 in 2008
Eric Cartman
Ireland 2010 Range Rover Autobiography TDV8 Santorini Black
So Ive seen that you can use a 2006 remote control for the RSE in models up to 2012 , so the question is, does a 2010 touch screen fancy remote work in a 2007/2008 model with RSE ?
If so is it just a case of buying the remote and the dock and wiring it in to charge and away I go ?
Post #359588 29th Nov 2015 5:02pm
mzplcg
If the early remote works in later cars it seems the IR codes used are the same so theoretically the reverse should be true. If anyone close to me has a pre 2010 car with RSE I would be happy to try my 2011 remote to prove or disprove the theory.
Post #359718 30th Nov 2015 9:12am
Eric Cartman
cheers. Id like to know as Id say it would be a brilliant retrofit for those with 07-09 cars with RSE.
Post #359795 30th Nov 2015 3:19pm
