Home > Technical (L322) > Headlight Questions |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35265 |
do you mean the main inner lights being yellow'ish.. ... - .- -.
29th Nov 2015 9:50pm |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7923 |
The sidelights & high beam are yellower - regular bulbs
forever Member Since: 06 Oct 2015 Location: Oxted Posts: 319 |
Yes the inner ones, plus the ones that come on when turning, if they can be replaced any recommendations? Thx |
29th Nov 2015 9:57pm |
the mains are H7 and the cornering are H8..
29th Nov 2015 10:04pm |
Zirconblue Member Since: 16 Apr 2015 Location: Kent Posts: 1277 |
The inner ones are just fill in lamps. The actual xenons do both the main beam and high beam, but the halogen is there to fill in the time it takes for the shutter to move out the way of the xenon to give you full beam.
Thanks Stan, maybe led is the way forward anything to watch out for given the canbus system? |
29th Nov 2015 10:05pm |
Thanks Zirconblue you don't recommended LEDs? |
29th Nov 2015 10:06pm |
I've used them on my mini, the problem you have it finding ones that will fit in the hole or lamp holder, i've found them in the past where they wont go far enough into the lamp holder to engage the bayonet. I've also had them where the individual LED's start flickering and failing. Some of them don't even give a very good beam pattern, because the reflector on the lamp isn't designed for them, they're not as bad as those god awful after market HID kits people fit, but the light while very bright tends to flood everywhere rather than be focused where it's supposed to go.
29th Nov 2015 11:15pm |
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1350 |
I'd say the shutter moved faster than the halogen bulb reaches full brightness. AS for just being a gap filler, I feel they are more than that and definitely do add to the road visibility. I have a 7 series BMW where the outer xenons are dip and full , with the inner bulbs only being used for flash. xenon only full beam is pretty rubbish compared to the RR which has xenon + halogen full beam. So much so I'm looking for a way to make the BMW inner lights come on with the full beam as well. V8 or else ... |
30th Nov 2015 7:46am |
Lost for Words Member Since: 18 Jun 2015 Location: Warminster, Wiltshire Posts: 473 |
Dont put LEDs in the main headlights - they won't produce a decent beam, as they can't match the charicteristics of a narrow filament. The cornering ones, probably yes (I have them in my D3's cornering lamps and the effect works).
30th Nov 2015 9:33am |
Does that apply to the Osram night breakers, i always thought they gave a good light plus it was more white than yellow.. |
30th Nov 2015 9:37am |
It applies a little, but not to the extent of many others. They do produce good amount of light, because they compensate by running the filament harder, hence the poor bulb life that is observed from them.
30th Nov 2015 9:54am |
That's what I've always done
30th Nov 2015 9:59am |
Here's a post I wrote on the subject on Defender2:
Visiting from DISCO3.CO.UK Discovery 3 TDV6 Auto HSE Zambezi Silver |
30th Nov 2015 10:14am |
