Home > Off Topic - Other Cars > Classic RR Headlights... |
markdotreed Member Since: 05 Sep 2011 Location: Ropley Posts: 741 |
I want to upgrade the standard H4 headlight candles in my classic. Has anyone got any suggestions?
24th Nov 2015 9:33am |
I guess I've been looking at the Boy Racer sites then as they're far from hundreds of pounds..... I'l have a look..
24th Nov 2015 10:45am |
Martin Site Admin Member Since: 24 Mar 2007 Location: Hook Norton Posts: 1665 |
Any HID conversion is technically illegal as the H4 lamp is not designed for an HID source, only normal bulbs.
24th Nov 2015 10:58am |
Oddly enough Martin, I was just going over to one of the other sites to see if there was any comparisons when searching....
24th Nov 2015 11:02am |
I use uprated H4 bulbs in the standard headlights.
24th Nov 2015 11:04am |
I've just ordered 'Osram Nightbreakers' and a pair of crystal reflectors.... Will put up a picture of the 'before and after' Regards
24th Nov 2015 11:15am |
IanT599 Member Since: 15 Jun 2013 Location: Wellington Posts: 351 |
Are there proper xenon upgrade kits for the defender and classic?
24th Nov 2015 11:16am |
V8Noise Member Since: 25 Apr 2015 Location: Dereham Posts: 424 |
That's the way to do it. The only alternative would be Phillips Extreme bulbs. I did this on my Defender and it was like night & day. I bought HIDS for it but never fitted them after the crystal and bulb upgrades, Didn't need to. 2017 5.0 Autobiography Supercharged 2005 Merc SL350 2005 Disco HSE 2.7 oil burner |
24th Nov 2015 12:24pm |
3528cc Member Since: 29 Oct 2014 Location: North East Posts: 301 |
I would fit the Wipac Clearform lamps, I resisted fitting them to my '94 classic for quite a while, but eventually fitted some, they are a vast improvement even with standard bubs, better again with improved performance bulbs.
24th Nov 2015 4:42pm |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3657 |
An HID conversion has to be self leveling to be legal....... the ffrr gets around this because the suspension is "self leveling" on a good day when it's not throwing a fit So you should be able to fit HID's to a later classic, provided that it has Air Suspension and it will also need headlamp washers to comply with the law Yesterday I couldn't spell Engineer... Today I are one!
24th Nov 2015 11:35pm |
If it's for a RR Classic I think the Defeaner LED ones in most LR mags would fit. Road legal as they're not HID, don't need wash systems or self leveller. Very bright. |
25th Nov 2015 10:24am |
Fitted these on Sunday morning and am very impressed with the results. A huge difference.
2nd Dec 2015 8:08am |
